TPM failure?
Old Aug 8, 2009 | 09:26 AM
Dream Tire's Avatar
Dream Tire
Default TPM failure?
Hey Guys,
I have had my Vette on the road since last friday. The day I got it from the Dealership they included a set of factory C6 18/19 wheels with TPMS and GY RFTs.
No issues what so ever with TPMS.
I was driving last nite and all of the sudden I get the tire message "check pressure sys." or something like that. I checked through the controls to see if maybe one tire is getting low but all it shows is:
LF: XXX RF:XXX
LR: XXX RR:XXX
Im going to take the car to the shop on Monday to have my guys scan it. I was wondering if their is any fault with these units?
Old Aug 8, 2009 | 09:30 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Does your key fob still work? If not check fuse 27 in the passenger wheelwell fuse box. If that's not it pull your codes.
It's possible you have the wrong year TPM's installed on the wheels (C6's).
Old Aug 8, 2009 | 09:40 AM
Dream Tire's Avatar
Dream Tire
That was my first guess. But they I would get this message day 1 of driving the car with these wheels. I got it 1 week later.
The system would recognize pressure changes.
Old Aug 8, 2009 | 09:49 AM
Mark C5's Avatar
Mark C5
People with no TPM's go weeks without getting the message so yes, it's possible to not have gotten the message until now.
A couple weeks ago there was a thread posted by a member who installed C6 sensors on his C5 and claimed they worked, no error messages and read pressure. A week later he posted he was mistaken, they had stopped working. Your problem sounds very similar.
Old Aug 8, 2009 | 10:00 AM
Dream Tire's Avatar
Dream Tire
I guess then ill start by putting the stock front wheels on it and see if it will read it.
If so, then I will swap the sensors over.
Thank you
Old Aug 8, 2009 | 01:49 PM
Bakersfield's Avatar
Bakersfield
Thank you
No need to put the stock wheels back on just yet. Try training the new sensors in your new wheels first and see if that corrects the problem. If that doesn't fix it, then move the stock wheels close to the car, go through the training process again with them and see if they start reading tire pressure. The receiver will pick them up even if they are not mounted on the car. That will eliminate the receiver and verify the problem is in your new wheels. Also check the valve stem on the new wheels, are they metal or are they rubber? If they are rubber, then they are not the sensors. Good luck.
Old Aug 8, 2009 | 02:08 PM
byronhunter's Avatar
byronhunter
Read this, some good lessons learned!!!
http://forums.corvetteforum.com/c5-t...atibility.html
Old Aug 8, 2009 | 05:34 PM
Dream Tire's Avatar
Dream Tire
Both sets have sensors.
But today as I was driving, out of no where the sensors started functioning again. Except that it is showing a 4 psi difference in the fronts. This I find a little hard to belive because the whole week I was running 29 all around. As I would drive, the left rear would jump up by 8 PSI and kick off the light. So I put nitrogen and it solved that problem.
I know for sure that the nitro did not leak out 4 PSI over night. And the sensors were reading correct tire pressure before the error.
I guess Ill keep an eye and see what happens. Worst sense one night at the shop Ill mess around and swap the sensors. Just not looking forward to r/r 8 RFTs
Rod
Old Aug 10, 2009 | 10:10 AM
Bakersfield
I think you should go through the TPS training process. It only takes a couple of minutes and it might solve your problem. That way you will know the RF is the RF and so on. Hope it keeps working for you.
Old Aug 10, 2009 | 12:12 PM
byronhunter
Rod
Dream Tire, if you park the car anywhere near where the original tires are stored, your car is reading the signal from the original sensors.
Old Aug 10, 2009 | 01:06 PM
Dream Tire's Avatar
Dream Tire
The car is no where near the original wheels, nor was it beside another c5.
The sensors picked back in when I got in my car after work. So far everything is working and reading fine.
I guess I'll keep an eye on it and post what happens.
Rod
To TPM failure?
