Oil P.S.I. sending unit
Old Aug 9, 2009 | 08:34 PM
wiz1500's Avatar
wiz1500
Default Oil P.S.I. sending unit
Quick question. Where is the oil P.S.I. sending unit at on my LS 1....I have 130 psi showing on the DIC I'm assuming that the sender is bad.
Thanks in advance...
WIZ
Old Aug 9, 2009 | 08:43 PM
Daddyrama31's Avatar
Daddyrama31
Hi fellow Michander. It is located just behind the intake. BTW, I have a brass sending unit for sale. There are many threads on how to Change, just do a search.
Good Luck
WIZ
Old Aug 9, 2009 | 08:45 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Yes, sounds like the sender is bad. The sender is located behind the intake manifold on the drivers side. Take a look at the sticky at the top of this page titled "Oil Pressure Sender Relocate". It will answer most if not all of your questions.
Old Aug 9, 2009 | 09:11 PM
Daddyrama31
To Oil P.S.I. sending unit
