Service Active Handling?
Old Aug 12, 2009 | 08:15 AM
Newfreedom's Avatar
Newfreedom
Default Service Active Handling?
Hey Everybody,
I need some help. The last three times I have driven my car the service active handling light comes on and says to service vehicle soon. This is not a daily driver and it driven less than 100 miles a month. Once the car has been shut down over night the light clears and doesn't come back on until I've driven it for a while. Like maybe 10 miles or more. Any ideas on why this is happening? As usual Thanks for your help!
Old Aug 12, 2009 | 09:21 AM
Zer0vette's Avatar
Zer0vette
Sounds like your abs/tcs unit is going bad. Some people have had success with checking grounds and looking for corrosion, but i doubt you have that with the miles on your car. You can either replace it the EBCM or get it repaired. I went through these guys on ebay to repair mine...
http://cgi.ebay.com/ebaymotors/CORVE...Q5fAccessories
absfixer.com is also good for the same type of service.
Old Aug 12, 2009 | 11:57 AM
dougbfresh's Avatar
dougbfresh
Post your codes.
Old Aug 12, 2009 | 12:06 PM
Newfreedom's Avatar
Newfreedom
How do I get those codes?
Old Aug 12, 2009 | 01:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The simple version is push and hold the fuel button and touch the options button four or five times in like 5-7 seconds or so. That will start the code process. You can use the other buttons to manually go through the codes to identify individual codes and clear them as desired. The E/M button will exit.
Old Aug 12, 2009 | 01:54 PM
Zer0vette's Avatar
Zer0vette
see http://www.stengel.net/diccodes.htm
Old Aug 12, 2009 | 03:25 PM
Newfreedom's Avatar
Newfreedom
Thanks so much. I'll get back to you guys with the codes and go from there. Thanks Again!
Old Aug 12, 2009 | 03:53 PM
jellyjam's Avatar
jellyjam
Can the abs/tcs unit be unstuck by just appling the brakes like in a panic stop several times to exercise the unit ?
Old Aug 12, 2009 | 07:17 PM
97C5owner's Avatar
97C5owner
Pull the relays and fuses and try to reset the system. Mine does this about every 8 months. I just pull the fuses and relays- makes it happy again. These C5's have so many intermittent electrical gremlins. Usually just as easy to banish as they are to aquire!!
Old Aug 13, 2009 | 07:56 AM
Newfreedom's Avatar
Newfreedom
Which relays and fuses should I pull? Thanks!
Old Aug 13, 2009 | 08:21 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Sitting or driving makes little if any difference on the grounds. You live in a salty air environment which makes it even worse. I highly recommend you go to the top of this section and go through all of your grounds. It isn't difficult or too time consuming and well worth doing.
Old Aug 13, 2009 | 12:42 PM
Newfreedom's Avatar
Newfreedom
I'll do it. Thanks!
Old Aug 18, 2009 | 06:26 PM
Newfreedom's Avatar
Newfreedom
Here are the codes everyone.
99 HVAC
BO 361
BO 441
BO 446
Thanks!
Newfreedom's Avatar
Newfreedom
And I forgot to say that these are the current codes.
Thanks Again!
Old Aug 19, 2009 | 11:59 AM
dgrant3830's Avatar
dgrant3830
99 HVAC
BO 361
BO 441
BO 446
Thanks!
B0361 Left Actuator Feedback Short to GND
B0441 Left Actuator Out of Range
B0446 Right Actuator Out of Range
You might want to post the history codes too in this case. These above are all HVAC related, not the active handling or associated systems
Old Aug 20, 2009 | 10:25 AM
BLUE Y2K's Avatar
BLUE Y2K
My ABS & Active Handling lights were acting the same way and eventually the lights were on whenever the car was running. It turned out to be a front wheel bearing.
To Service Active Handling?
