I just replaced mine with the wheels off and the car on jackstands and There's no reason why you can't do it up on a lift, but, I think it would be awhole lot easier with the tires off. I appreciated the fact that I could get in there to remove the nut on the bottom A-arm at the rear with the tire off. I think it would be tons easier, but, then again I'm an old geezer and easy is important.
• What is the best lube to use on the new insulators?
• What is the best way to get a torque wrench on the end links? Using the torx head to hold the threaded stem still and tightening the nut or trying to get an open end wrench around back between the rubber boot and the end link and torquing the nut with a socket?
Just MHO
best lube : I uses SylGlyde but another post suggested teflon tape around the sway bar
best way to get a torque wrench on the end links : get an open end wrench around back between the rubber boot and the end link and torquing the nut with a socket.........easier with the wheels OFF
