CAGS question
Old Aug 15, 2009 | 12:30 PM
razzer's Avatar
razzer
Default CAGS question
I am trying to disable the CAGS. I got the plug listed on the net and added the correct resistor. So far, so good. I crawled under the car yesterday to find that I'm not sure where/which plug needs to be disconected. I see a plug going to a solonoid (pointing stright out from trans) with a wire cover that is tagged "skip". But it has the wrong style plug, based on the info on line. It has a blue/white plug that does match what i read for the correct color, but still wrong plug style. The one i found on the web is a GM weathertite connecter that has two round barrel style treminals.... the one I find on the car is a two pin rectangle similar to a gm fuel injecter.
Old Aug 15, 2009 | 02:22 PM
byronhunter's Avatar
byronhunter
Skip Shift Solenoid Connector:
Old Aug 15, 2009 | 02:40 PM
razzer's Avatar
razzer
thank you!! The info i got was wrong then...... i'll get it now....
To CAGS question
