Rattle in Dash
Old Aug 16, 2009 | 02:44 PM
vettn71's Avatar
vettn71
Default Rattle in Dash
I have a rattle in the left side of the dash. I thought it was my HUD, but when I hold it down I still have the rattle. It also doesn't seem to be the gauge cluster or the steering column angle adjustment lever. Any ideas what else is in that area that would do this. I have to hit a sharp bump for it to make noise, but its irritating and its getting more pronounced.
Jim
Old Aug 17, 2009 | 12:52 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
There are two brackets that support the IP Cluster from below. I found on mine that one had a stripped screw from the factory. It caused a rattle. Oh yes, its sharp on the edges as I found out the hard way.
Old Aug 17, 2009 | 02:05 PM
BigGun's Avatar
BigGun
Jim
I have the same type of rattle in the same general area. Let us know if you find it. I have been putting off going into the dash but it seems to be getting worse. B\G
Old Aug 17, 2009 | 06:19 PM
vettn71's Avatar
vettn71
Dgrant3830
Can you access that part of the cluster from the bottom or do I have to disassemble the whole thing? Sounds like that's where my problem is.
Jim
Old Aug 17, 2009 | 07:08 PM
redrckt97's Avatar
redrckt97
mine makes a pretty sharp rattle in that area too - but if I hold
my finger between the column and the far left end of the radio bezel, it stops - haven't tried to fix it yet - might check yours
To Rattle in Dash
