Door squeak
Old Aug 17, 2009 | 02:09 PM
puzzleboy's Avatar
puzzleboy
Default Door squeak
On my 2000 Vert, the driver's door squeaks loudly when opened. I've lubed it several times of course.
There is a roller on one of the hinges that is near impossible (gravity) to get lube into (between the roller itself and it's spindle), and that's what's squeaking on my car.
It looks like it's permaswaged in place. Has anybody a way of lubricating this? Drill a hole through the roller maybe, to allow grease/oil in?
Any ideas would be great!
Thanks.
Old Aug 17, 2009 | 02:42 PM
k0ts's Avatar
k0ts
I have the same problem and would like to know a good fix..
Old Aug 17, 2009 | 03:51 PM
killain's Avatar
killain
Oldtimer
Go to NAPA and get a small tub or tube of Chassis grease, and an small acid brush. Then you gat grease the hinges no matter if they are upside down or not. The chassis grease is thicker and won't evaporate away. Benn doing this for the last 40 years and it works every time.: yesnod:
Old Aug 18, 2009 | 06:07 PM
puzzleboy's Avatar
puzzleboy
Thanks for the info! Anybody else?
Thanks,
Old Aug 18, 2009 | 06:29 PM
Black04Z06's Avatar
Black04Z06
I use a bike grease gun with white synthetic lithium grease.
If you shop around you can find them with long needles to get into the tight spots.
Here's an example. Mine has a longer needle.
To Door squeak
