Pulling to the right!
Old Aug 17, 2009 | 11:26 PM
enigma94's Avatar
enigma94
Default Pulling to the right!
So I had a clunking noise coming from the rear, and I could never figure out what it was ( as per this post : http://forums.corvetteforum.com/c5-t...ear-wheel.html)
now the car seems to pull to the right really bad as i give it gas then pulls to the left after i let off, it also seems to be following the road a lot as well. I checked the rear cradle bolts and they were all tight and I havnt touched the front end at all so im kinda baffled as to what it could be. Any suggestions on where to look and what to look for would be great!
Old Aug 18, 2009 | 12:00 AM
pcbunn's Avatar
pcbunn
4 wheel alignment needed! Mine did the same thing and my suspension guru identified it as the rear wheel pushing to the right. He made the necessary adjustments and now straight as an arrow. It was well worth the expense.
Old Aug 18, 2009 | 12:05 AM
enigma94's Avatar
enigma94
Yea i definately need an alignment, since I have yet to do one since I installed my coilovers but it JUST started happening kinda out of nowhere after installing the tranny mount and the noise popped up so I dont really think its that
Old Aug 18, 2009 | 12:32 AM
lucky131969's Avatar
lucky131969
So if you definitely need an alignment, why do you continue to drive the car in this condition..? Perhaps if you get the car into a shop for an alignment, with techs that know what to look for, they may find the problem that eludes you....
Old Aug 18, 2009 | 12:36 AM
enigma94's Avatar
enigma94
well I have 2 issues, I have yet to find a shop around me that can corner balance/align the car because its so low and wouldnt even make it on a rack so im still in search for a shop with a pit to do the alignment. And I'd rather not pay labor prices for them to fix something I can do myself, but I guess if I cant get any solid ideas from people who have experienced this in the past then I will just have to bite the bullet and take it to a shop
Old Aug 18, 2009 | 12:40 AM
lucky131969
I guess you can wait..until either something really breaks, you trash your tires, or have an accident.....all of which will probably be less expensive than taking it to a shop...
Old Aug 18, 2009 | 03:07 PM
enigma94's Avatar
enigma94
sooo what you're really saying is you have no idea what it could be? Thanks...
Old Aug 18, 2009 | 03:11 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
It's completely possible the alignment just got worse and that's all that is wrong. Get that fixed. Trying to diagnose a problem on top of an existing problem is damn near impossible, especially over the internet.
Old Aug 18, 2009 | 04:05 PM
87SAM's Avatar
87SAM
You could take some 2X4" boards to the shop to use as ramps to get it on the rack.
Old Aug 18, 2009 | 04:40 PM
lucky131969
Sight unseen....nope. Could be many things, but you have to establish a baseline from which to troubleshoot. If you know the car is in need of an alignment, then that's the place to start. While the car is up in the air, other components can be inspected for wear, damage, etc. What do you want, someone to figure out what got worse, after YOU worked on it last, without driving, inspecting the car? .....seriously....
Don't blame me because you can't figure out your own car........one thing is for sure...if it was mine, it would have been aligned by now.....
Old Aug 18, 2009 | 09:26 PM
enigma94's Avatar
enigma94
Well its not, I wasnt asking for somebody to point out the obvious in that the car could use an alignment but I've driven the car for a year and a half after the coilover install and it never pulled or followed the road so I find it highly unlikely that out of nowhere it would start causing issues. I was simply wondering if anybody had this issue after installing the Pfadt tranny mount in that it is common and has a easy fix thats all. I'm not blaming anyone I just find it humorous that you cant understand the fact that I dont want to pay some random mechanic to fix what I could do myself for free. I daily drive the car so i dont have time to sit under the car checking everything at just a whim so i was trying to eliminate that guessing process but I guess thats just asking too much.
To Pulling to the right!
