So about 2 years ago i had to replace the front knock sensor b/c it went out. i figured it was from washing the motor. SO for the past 2 years i bit the bullet and not cleaned my engine bay with water. (occasinally i'll clean it with a damp towel)
and NOW the sensor has gone out again. at $50 the sensor is 2 expesnsive to keep replacing.
Why has it gone out again? is it possible the wireing harness is broke not the sensor? how could i tell
2 possibilities, water from the top or oil from the bottom (there is a seal in the bottom of the well the sensor lives in). I replaced the seals on the bottom when I did mine and used form a gasket around the top to keep stuff out from the top.
GM had a tech bulletin on using a high temp sealant to build up a ridge around the top of the sensor well to keep water from running down and collecting in the well..
Originally Posted by lucky131969
Did you seal up the knock sensor valley cover last time you replaced it? there is a TSB on this.....
just beat me Lucky....
