HELP PLEASE Code C1226
Old Aug 21, 2009 | 03:41 PM
EtidW's Avatar
EtidW
Default HELP PLEASE Code C1226
I have a 2001 coupe. I am getting code C1226. My info says it is- LF excessive wheel spin variation- Anyone ever changed that sensor or know where it is located.. It could be the wiring as the alarm comes on after hard bumps so if anyone knows where the ground is that may be a good starting point.
Thanks Wayne
Old Aug 21, 2009 | 04:52 PM
trussme's Avatar
trussme
Default C1226 is actually the Right Front wheel sensor
Wheel Speed Sensors: DTC C1226 RF Excessive Wheel Speed Variation indicates R F (not LF) wheel speed sensor is either sending a bad signal or no signal. Start by checking the connections. The wheel speed sensors are integrated into the wheel bearing/hub assembly. The wire coming out of the back is the connection for the wheel speed sensors. Verify that the connector are not broken, damaged, or corroded in any way. Pay particular attention to the female end.
The wire coming out of the wheel speed sensor connects to and 18" jumper harness, then to the main harness. It is very common for people to have a weak female pin in one of those connections. If all of that checks out good, swap the jumper harness from side to side. For example if the left front is bad, swap it over to the right front. And install the good one from the right front to the left side. Then clear the trouble code. If the trouble code is now on the right side, you know the wire harness is the problem. If the code is still on the left side after swapping the jumper harnesses, you know the problem is inside the wheel speed sensors.
If all the wires check out good, it's time to take a trip to Auto Zone for a new set of bearings. You can buy replacement AC Delco bearing from your dealer if you want to, or get the exact same bearing in a different box for half the price (~$150) from Auto Zone, you decide. The bearings should be replaced in axel sets, so if your left front is bad, you have to replace the right front too. While you’re at it, this is a good time to upgrade the lug studs and add spindle ducts
