Power door lock problem....very weird
Old Feb 18, 2002 | 11:07 AM
shizon'00's Avatar
shizon'00
Default Power door lock problem....very weird
My power lock won't lock the driver side door. It will unlock it just fine, but won't lock it. Any idea? Don't really want to make a dealer trip. It's out of warranty anyway :)
Old Feb 18, 2002 | 01:01 PM
silver z's Avatar
silver z
Default Re: Power door lock problem....very weird (shizon'00)
I had the same problem with my 2001 ZO6. Try holding the lock and unlock buttons on the drivers door at the same time. This worked for me. If that does not work then its off to the dealer.
Good luck.
Old Feb 18, 2002 | 01:47 PM
mac1009's Avatar
mac1009
Mine has the same problem unlocking. I've just been too lazy to replace the module. There have been some recent threads about this. I think it's the door control module, but I"m sure somone who knows for sure will chime in.
Dave
Old Feb 18, 2002 | 01:58 PM
Scissors's Avatar
Scissors
☠☣☢ Semper Ebrius ☢☣☠
Cruise-In IV-V-VI-VII Veteran
St. Jude's Donor '06
Default Re: Power door lock problem....very weird (mac1009)
Dave
You are correct. Door panel removal and replacement of the control module is straightforward. Instructions are on this site.
Old Feb 18, 2002 | 03:25 PM
shizon'00's Avatar
shizon'00
Default Re: Power door lock problem....very weird (Scissors)
is it one of those things that has to be replaced or just checked for a loose connection?
Old Feb 18, 2002 | 04:47 PM
C5XTASY's Avatar
C5XTASY
I had mine replaced under warranty. It was intermittent. It's a common problem with the C5.
Ed
Old Feb 18, 2002 | 07:23 PM
Speed-Racer's Avatar
Speed-Racer
Default Re: Power door lock problem....very weird (C5XTASY)
Mines intermittent, and checked all the connections to it. Still does it now and then, so a replacement is needed. Oddly enough the dealer did not replace the darn thing because the door lock worked fine for them.
George
Old Feb 19, 2002 | 08:51 AM
C5XTASY's Avatar
C5XTASY
Default Re: Power door lock problem....very weird (Speed-Racer)
George
I'm not sure, but I think it may set codes for this problem. Have them check next time you take the car in to verify it. They should have replaced the module.
As I mentioned, mine was intermittent, also. It's a common mode of failure for these things and they should have been aware of it.
Ed
To Power door lock problem....very weird
