Head/Piston Compression Combo?
Old Feb 18, 2002 | 04:20 PM
kromberg's Avatar
kromberg
Default Head/Piston Compression Combo?
I am looking for a head and piston combo that would produce a compression level of about 12.5:1 to 13.0:1. I have checked some of the sponcers, but the level one I have found is 11.0:1. I was wondering if anyone knows where I could buy a set I am looking for. And yes, I know I would have to run race fuel all the time :) TIA.
Keith
Old Feb 18, 2002 | 06:59 PM
Godspeed's Avatar
Godspeed
Senior Member
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Head/Piston Compression Combo? (kromberg)
I would give Nick/ARE a call. The trick to raising the compression that much will be having smaller combustion chambers - I would guess around 50-52cc. I know it is possible since they did a 422 that came out to 13.9:1 CR.
-Jeremy
Old Feb 18, 2002 | 07:55 PM
EuG's Avatar
EuG
It’s easy if you’re gonna change the pistons.
Just get the correct spec pistons (domed most likely) that will yield desired CR for a given CC head.
Old Feb 19, 2002 | 09:34 AM
kromberg's Avatar
kromberg
Thanks guys for the info :) I will definately give Nick a call. Once again, thanks.
Keith
To Head/Piston Compression Combo?
