Clutch question
Old Aug 25, 2009 | 12:02 PM
crimsonc5's Avatar
crimsonc5
Default Clutch question
Please delete
Old Aug 25, 2009 | 12:17 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Originally Posted by crimsonc5
I just had a new clutch, pressure plate, throw out bearing, master, slave and new flywheel installed. I know it's the break in period, but as I pull in the driveway or doing a slow ingage it feels like it hesitates? Could that mean it needs adjusting? Pavlock put In an adjusable master as well. It's been along time since I have had a new clutch so maybe as it breaks in it will stop? Any answers are highly appreciated.
Thanks Alan
Difficult to get an idea of what you're trouble is. If the pedal engages in a reasonable position the no adjustment should be needed. Go get yourself stuck in some stop and go traffic in the downtown Houston area around 8am or 5pm (drivers' choice ) and by the time you get home, your clutch will be broken in. Many clutches will chatter when you're trying to slip them if that's what you're talking about. That subsides after a decent amount of driving in most cases.
Old Aug 25, 2009 | 12:28 PM
crimsonc5's Avatar
crimsonc5
Yes chatter is what it's doing. I never though of breaking in that way. I will get on 290 around 5 today, that should do it thanks for your help.
To Clutch question
