LS3 crate swap. what else does it need
Old Aug 25, 2009 | 10:28 PM
Bad97ta's Avatar
Bad97ta
Default LS3 crate swap. what else does it need
if i was going to drop in an LS3 crate engine to replace my LS1 what do i need to replace or make it work. i have an A4.
Old Aug 25, 2009 | 10:39 PM
JonLT4CE's Avatar
JonLT4CE
For starters you will have to change the crank. The reluctor wheel has a different amount of teeth.
Old Aug 25, 2009 | 10:45 PM
lucky131969's Avatar
lucky131969
The reluctor wheel can't be changed?
Old Aug 25, 2009 | 11:19 PM
slothy's Avatar
slothy
easy mode
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
Old Aug 25, 2009 | 11:49 PM
glennd's Avatar
glennd
I ordered my LS3 with the same reluctor wheel as an LS1/6, from LME. It works great, you will also need to order an adaptor cable. Pretty simple ,as long as the +12 and ground are not reversed in the cable, as mine was.
Old Aug 25, 2009 | 11:55 PM
Bad97ta's Avatar
Bad97ta
was it worth it
Old Aug 26, 2009 | 12:37 AM
nuck's Avatar
nuck
I have been thinking about this sort of a swap for a while. If it was basically stock how much did it run you? How complete was it and how much of the LS1 peripherals worked? The LS3 has the different style injectors right? Are the engine electronics compatible?
I was thinking if my LS1 ever calved on me I would go for an LS6 so that I wouldn't have to buy a bunch of addional smaller parts to make it work. Or better yet an LS6 shortblock with some decent aftermarket heads.
Old Aug 26, 2009 | 08:26 AM
glennd's Avatar
glennd
I am very pleased with my LS3 from LME, they were a pleasure to work with. I purchased this through ECS. I have AFR 225's ported by Tony Mamo about 10/15 cfm above stock. Ported fast 90/90 (tony Mamo), methanol, 1 7/8" Kooks 9.2:1 c/r, LG Big 3 exhaust, hi flow cats, A&A, old style intercooler, D1SC 3.75" 8 rib, stock dia. damper, 15 lbs boost. SD tuning, 858rwhp 780 rwtq. Then I fixed belt slip with a stronger tensioner I got from Arun, was not able to get traction on the dyno. I am very pleased, however traction is a problem. I have tried Nitto's, BFG Gforce and Toyo R888's. I like the R888's best overall.
I do not recall the price for the short block, however I thought it to be a good price for quality parts and labor.
Old Aug 26, 2009 | 09:31 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
was it worth it
I can't imagine that it's your most cost effective option. What are your goals? That's ultimately what we need to know to to know.
Old Aug 26, 2009 | 10:51 AM
minitech's Avatar
minitech
The reluctor wheel issue had been a problem but it is now solved with an electronic converter box so no problem.
I think it would be a cost effective way to go considering you can sell your old engine for some cash too. Lot of hot rod guys like the LS1 for builds. Would cost less than a turbocharger or supercharger and probably a good set of heads and a cam with labor.
And a new crate is under warrantee.
Old Aug 26, 2009 | 11:12 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have been doing LS3 conversions with the electrical cross over boxes from LPE, they work great. Good luck with your build!
Old Aug 26, 2009 | 11:36 AM
marinehacker202's Avatar
marinehacker202
how much do yall typically charge for those conversions?
Old Aug 26, 2009 | 12:45 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Doug,
I see alot more guys looking at the LS3 convertion. Maybe you can write up all the little parts they need to order, and about how much in a big ball park range ECS would charge for the swap.
Im selfish. When my motor goes, that's the direction im looking at also.
Old Aug 26, 2009 | 05:00 PM
Bad97ta's Avatar
Bad97ta
to answer your question on what my goals are.
since i have over 100k on the motor and trans, i think that i will add to much eventually to my old LS1. The problem is that i always will want more! so my goal now will change when i get used to the mods that i have made.
LS3 swap gives a warranty, and more room to build on later
Old Sep 30, 2009 | 04:03 AM
mickey_7106's Avatar
mickey_7106
im planing on an LS3 when my engine goes too
Old Sep 30, 2009 | 11:48 AM
11sec_C5Z51's Avatar
11sec_C5Z51
I was thinking the same thing
Old Sep 30, 2009 | 05:41 PM
hhntr111's Avatar
hhntr111
Me. too. I like the C5 body more than the C6, and the idea of an LS3, with the right peripherals, like headers, a tune, half shafts, is appealing.
To LS3 crate swap. what else does it need
Old Sep 30, 2009 | 08:00 PM
deadcafe's Avatar
deadcafe
Glad your not my mechanic! How about you read the question and stop trying to impress with big greasy mechanic talk....
Going to need new Muffler bearings as well, and the canooter valve has a completly different tune for the LS3 that it does on the LS1..
Old Sep 30, 2009 | 08:07 PM
Brandon619's Avatar
Brandon619
Originally Posted by slothy
, great product!
Old Oct 2, 2009 | 06:28 PM
mickey_7106
will it bolt up to my tranny? i thought i had read somewhere that it wont work. i cant find the thread where i read it
