a/c not cold
since I've lived in the Pacific Northwest, I've not needed my A/c a whole lot.
apparently, it's a use it or lose it thing, because I lost it.
It no longer blows cold. The fan itself works fine, but it's just air.
I hit the button for A/C and the light comes on, although every once and a while it'll blink and turn off. I hooked up a 134 gauge, and it read 70 Degrees ambient (I think, that was a few months ago, but I know it had refigerant in it)
any ideas?
Good luck Semper Fi
PS static reading on a full system would be around 90 to 110 psig, static being with the system off and pressures equalized.
I cannot hear it click off until I turn it off.
It's only done the "blinky light" thing twice to me. that's when I bought the bottle and charged it. But it still didn't blow cold.
I mentioned the ambient temp because that is what the gauge that came with my bottle reads, but that at least meant that it had 134 in it.
I do have an underdrive pulley, but I had that put on almost three years ago. A/C worked then.
The problem began after moving to the Pacific Northwest and not needing the A/C in a 60 degree summer (Olympic Penninsula, WA)
I've been underway for the past couple of months, but am getting ready to get back home, so I am hopng to get it fixed before I PCS transfer.
I was going through my laptop last night and I found this interesting program I bought from another forum member. It was a GM stand-alone Service Manual for GM cars/trucks.
It has a step-by-step diagnostic procedure for testing and troubleshooting the a/c system on the vette. This might be useful.
gotta buy a manifold gauge.
Semper FI
To BGDDYKWL, you also need to top up. There are other possibilities, such as an actuator problem on a dual zone system, but from your info, I would check the charge and bring it up to specs.
Below are the specs from the service manual
The below chart assumes testing at idle speed, after the system is on for at least 5 minutes. I personally prefer to use 2000rpm's because from experience I've found you get better results, but the chart below will work fine to.
A/C Performance Table Ambient Air Temperature
Relative Humidity
Service Port Pressure
Maximum Left Center Discharge Air Temperature
Low Side
High Side
13-18°C (55-65°F)--ambient temps
0-100%--Humidity
211-241 kPa (31-35 psi)--lo side
500-740 kPa (73-107 psi)--high side
8°C (46°F)--maxium center vent temp, yours may be lower
19-23°C (66-75°F)
Below 40%
193-223 kPa (28-32 psi)
780-1090 kPa (106-167 psi)
8°C (46°F)
Above 40%
209-239 kPa (30-35 psi)
730-1050 kPa (106-167 psi)
9°C (48°F)
24-29°C (76-85°F)
Below 35%
172-214 kPa (25-31 psi)
1020-1227 kPa (148-178 psi)
9°C (48°F)
35-60%
199-229 kPa (29-33 psi)
970-1300 kPa (141-189 psi)
9°C (48°F)
Above 60%
207-237 kPa (30-34 psi)
1020-1500 kPa (148-218 psi)
10°C (50°F)
30-35°C (86-95°F)
Below 30%
210-240 kPa (31-35 psi)
1130-1520 kPa (164-221 psi)
10°C (50°F)
30-50%
208-238 kPa (30-35 psi)
1190-1670 kPa (173-242 psi)
11°C (52°F)
Above 50%
205-235 kPa (30-35 psi)
1280-1910 kPa (186-277 psi)
11°C (52°F)
36-40°C (96-105°F)
Below 20%
226-256 kPa (33-37 psi)
1280-1650 kPa (186-240 psi)
12°C (54°F)
20-40%
218-248 kPa (32-36 psi)
1360-1870 kPa (197-271 psi)
12°C (54°F)
Above 40%
1520-2100 kPa (221-305 psi)
12°C (54°F)
41-46°C (106-115°F)
Below 20%
238-268 kPa (35-39 psi)
1460-1830 kPa (212-267 psi)
13°C (55°F)
Above 20%
1570-2100 kPa (228-306 psi)
13°C (55°F)
47-49°C (116-120°F)
Below 30%
1750-2090 kPa (254-303 psi)
14°C (57°F)
Becauce i think its some very good info, so im going to print it so i will have it. Thanks. dbiddle
And i was just reading your post ok?.. I did not want you to think i was stealing your info.
Take care and i hope you get it working ok?
