Injector ??
Old Aug 26, 2009 | 03:46 PM
jarda's Avatar
jarda
Default Injector ??
If link works to dyno sheets, Great for feedback. Now my problem is during run i was told injectors where running 90% + @ WOT so tuner whatever was done cranked up fuel pressure stayed at 90 % be ok till u drop down in alt. , i'm @ 6500 ft now . So as I later was told this, I said can't live with that they installed 36# dropped down to 58 if I remember. OK now my ?? is can u install new injectors rescale them in parking lot and have all fine ? Car went in for emissions and bombed hydro carb test.
These sheets were with stock injectors
Dyno Sheets
Added this with right monitor when i blip throttle puff good black smoke comes out .
Idle
Old Aug 26, 2009 | 05:03 PM
Todd157k's Avatar
Todd157k
Banned Scam/Spammer
Dyno Sheets
Idle
Well, you answered your own question. NO, it's not. Also, you didn't say 'how' he upped the fuel pressure (which may still be your problem 'cause you didn't put it back).
You'd need to (at a minimum) take it out on the fwy and log whats going on. Injectors aren't only about scale.
Old Aug 26, 2009 | 05:53 PM
jarda's Avatar
jarda
Will be upfront I know nothing about what i'm talking learning on run here. was that night they increased fuel up to 62 seemed to help Huh. That is when I stepped in fix it. Now as spending 25 years as an NHRA class racer have i seen egos & the fights they cause went straight to Mamo told him he sent right injector to them. Yesterday his quote was
" Someone would have had to rescale the injector table or it would be rich as hell!!! " Don't think he remembered about pressure or I didn't tell me which my bad. Hate keep buggin him. Great Guy
So today I start trying learn ask shop "oh tune looks fine cam way to much overlap Huh standard 224/228 from Mamo lot of people on here have said your kidding do u know how big mine is? And it passed. Have u ever had to try and be diplomatic with an engine guy?
Thank you for comment
Old Aug 26, 2009 | 09:10 PM
DIXZ's Avatar
DIXZ
I think it is time to find a new tuner.
If you have been racing for 25 years, you should think about tuning your own car. It is just a frame of mind, instead of using a screwdriver and timing light you use a computer.
Old Aug 26, 2009 | 09:46 PM
jarda's Avatar
jarda
Point me from scratch would be a Great help. Would love to do it myself. Least be able to see a problem ,now that would be nice Thank you
Old Aug 27, 2009 | 08:24 AM
glennd's Avatar
glennd
Hi: if you look at your uncorrected dyno sheet i.e the actual horsepower you will see the actual amount of horsepower your injectors are supplying at 90%. My guess is about 25% less than your corrected HP. Whatever that percent difference is, will indicate how much more fuel you will need to supply at a correction factor of one, which is aproximately what you will get at sea level (STP). Increasing the fuel pressure from 58 to 62 is small the difference in flow it is only about 2% as the pressure increase the flow increases as the the square root of the increase. I.e. an increase of 58 lbs to 116 lbs woul only net a 41% increase
Old Aug 27, 2009 | 05:08 PM
jarda's Avatar
jarda
u know as TODD157 suggested I would really like to get a list of hardware & software to set up this tuning learning curve can't screw up much worse than it is ,i know sure i can but do get tired of paying someone all the time to tell what the think it might be
To Injector ??
