5 # or 7 # pulley?
Feb 18, 2002 | 09:39 PM
5 # or 7 # pulley?
Which would be better on a stock bottom end ? 5 or 7 pound pulley?
I think I'm going with an ATI puffer.
Feb 19, 2002 | 01:25 AM
Re: 5 # or 7 # pulley? (aces)
should be able to handle 7lbs easy. I know of guys w/ 382ci all bore w/ similar rwhp & rwtq to the ATI 7lbs kit who's been racing day in day out w/o any problem.
Mine's gonna be a 7 pounder :D
Feb 19, 2002 | 06:38 AM
Re: 5 # or 7 # pulley? (boblackhardtop)
7#
Feb 19, 2002 | 09:26 AM
Cruise-In I, II, III, IV & V Veteran
CI-I & II Auto-X Champ
5# would definitely be better for your stock compression bottom end, but it should be able to handle 7#'s for awhile as well.
Feb 19, 2002 | 09:30 AM
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Re: 5 # or 7 # pulley? (MattG)
I agree with you Matt but lets take in consideration he is in Ca. and I believe 91 or 92 octane at best.. :)
Feb 19, 2002 | 10:55 AM
Re: 5 # or 7 # pulley? (CHRIS NJ C5)
Correction: in Ontario we get 94 octane Sunoco Gold...I used it in my 95 Firehawk which was pro Charged, with no problems..I am going with the 7lb and will see if 8lb could work... :eek:
[Modified by dbvettez06, 8:56 AM 2/19/2002]
Feb 21, 2002 | 02:11 AM
define awhile?
Feb 21, 2002 | 11:30 AM
I noticed that 'awhile' also, Matt , your thoughts? :confused:
Feb 21, 2002 | 02:26 PM
Re: 5 # or 7 # pulley? (dbvettez06)
I have no idea how long "awhile" will be. I was just basically saying that the 5# pulley is a lot more stock bottom end friendly than the 7#! :)
If you want to ensure reliability of your stock bottom end at higher boost, check out this post:
http://forums.corvetteforum.com/zerothread?id=242826
[Modified by MattG, 1:28 PM 2/21/2002]
