You need to also replace the bolts in the valley pan with button heads ( I think that is what they are called.) They are a lower profile and are needed.
Also, you need to replace the small water tubes under the intake. You will get a crossover for the front and two plugs for the rear. Gene can help you with the part numbers.
Good luck!
Thanks...I already have the crossover and block off plates for the rear installed under the ls6 intake.
I wanted to run the bigger (Z06) Maf .Is there a harness that is needed to retro fit the older smaller Maf?
I also need some way of connecting the fresh air line from the pass. side valve cover to the air intake tube.
Some people have teed into the catch can instead.
I am wondering which is better?
