Security light won't go away
Old Aug 28, 2009 | 08:09 PM
yamahajo's Avatar
yamahajo
Cruise-In 9-10-11 Veteran
St. Jude Donor '08-'09-'10,-'13
I believe in the Beer Fairy
Default Security light won't go away
Started a thread a few days ago when the ignition locked up on me. I finally got it replaced today with a new(ish) one, and the car started right up!
However, the security light will not go out. What might be causing this, and how can I clear it up??
Old Aug 28, 2009 | 08:21 PM
NeutronVette's Avatar
NeutronVette
Have you tried to pull key, wait 10 seconds?
Old Aug 28, 2009 | 08:23 PM
thetaxman's Avatar
thetaxman
did you pull the codes ?
yamahajo's Avatar
yamahajo
Haven't seen that one pop up yet. I might have finally fixed it.
But thanks for the suggestion sarcastic sam. I didn't think you ever left OT.
Old Aug 28, 2009 | 08:26 PM
NeutronVette
Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occured in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
Codes here:
http://www.stengel.net/diccodes.htm
Old Aug 28, 2009 | 08:31 PM
NeutronVette
Also:
Long shot but do you carry a bunch of stuff on your key ring?
One guy had a problem with all the extra weight unseating the key so the resistor pellet wasn't making contact and bringing on the security light
Try it with just the key and see if its better. If so you might need to use the spare key (or lose the bling).
The other issue could be a worn ignition barrel
Old Aug 28, 2009 | 08:43 PM
yamahajo's Avatar
yamahajo
no other keys on the ring at all - shouldn't be a worn barrel - it came from a car with ALOT less miles and years on it than mine.
Old Aug 28, 2009 | 08:45 PM
NeutronVette
Skimming through these might help.
http://forums.corvetteforum.com/sear...rchid=12197538
Old Aug 28, 2009 | 08:51 PM
yamahajo's Avatar
yamahajo
Sorry - no matches. Please try some different terms.
go back to OT.
Old Aug 28, 2009 | 08:58 PM
NeutronVette
go back to OT.
Works for me, although apparently my powers are weak here.
Search "security light" Lots of hits.
To Security light won't go away
