I just put 315/30/18's in the rear and coupled with the 275/40/17 up front, it looks rediculous... What tires should I get for the front to even out the sidewall appearance with the rear? This is for the stock 17" & 18" set up.
Should be within 5 of the aspect ratio.
Ex: 245/40-17 & 275/35-18
You need 35's for the front with those rears or get 35's for the back with those fronts.
With a 17" front...you will not find a tire with as little sidewall as your 315/30 rears have.
A 245/40/17 is about the shortest tire available that will fit a 17x9.5" wheel.
If you had 18" fronts, a 285/30/18 would be a good match for those rears.
