Tips on removing rear coupe hatch?
Old Aug 29, 2009 | 06:52 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Default Tips on removing rear coupe hatch?
Any tips appreciated. PITA is my car is up on jack stands (high) in a tight garage. I have a new one with lexan going in to save weight. Thanks.
Old Aug 29, 2009 | 07:35 PM
Askeland's Avatar
Askeland
You nedd someone to help you hold the hatch open.
Disconnect dampers and wires to heat treads and antenna.
Put hatch down but don`t lock it down.
Remove interior targa panel (4 plastic clips)
Hatch is held in place by 4- 13mm nuts.
The hinges are also glued on, but no need to heat.
Grab one side each an gently lift the hatch STRAIGHT UP.
Glue will come loose and you are done.
Old Aug 29, 2009 | 07:44 PM
John Shiels
thanks a million I guess it is fairly heavy with the glass The lexan hatch I can handle fairly easy. I'll prop it open till I get everything lose and off. Toughest part will be removing all the crap I piled on the back of the car.
Old Aug 29, 2009 | 08:16 PM
Askeland's Avatar
Askeland
Not to heavy. . . I was supprised.
Remember to post pics
Old Aug 30, 2009 | 01:47 PM
MattB's Avatar
MattB
What lexan window did you go with? I have a second hatch and was thinking of the same thing.
Old Aug 30, 2009 | 04:36 PM
John Shiels
used hatch & lexan for 300 bucks
shields makes them no pun intended I will weight it to see the difference. May be next weekend I'll swap them
http://www.racingshields.com/
To Tips on removing rear coupe hatch?
