Lowered on Stock Bolts??
Old Aug 31, 2009 | 09:37 PM
TBH94's Avatar
TBH94
Default Lowered on Stock Bolts??
I have a 2003 Z06. I tried to lower it following the directions and photos I found on another Vette website.
The question I have is that I don't have a bolt with a nut on the front spring. I just have a stud with a 10mm end that threads through the spring and is attached to a bushing on the bottom. The bushing is attached to the control arm and when I turn the stud it looks like it will tear the bushing.
Can anyone tell me what I am doing wrong? Can I just turn the stud and the bushing will not rip?
Any help would be great.
Old Aug 31, 2009 | 10:34 PM
Dennis Wilson's Avatar
Dennis Wilson
When you have the car jacked up You have to use a small jack under the end of the spring to lift it up slightly to take the pressure off the bushing then it should turn easily. Turn it counter clock wise so you see more threads above the spring til it stops then back it off slightly.If you want it lower you can cut some or all of the bushing off. Good luck.
Old Sep 1, 2009 | 07:00 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
You will need to use lots of penetrating fluid.
Old Sep 1, 2009 | 08:48 PM
TBH94's Avatar
TBH94
Thanks for the info.
Just wanted to make sure I could turn the stud with the bushing attached without damaging the bushing.
And, yes, ipuig, I need lots of penetrating fluid. I keep spraying it hoping it will free up.
Old Sep 1, 2009 | 08:52 PM
cptinjak's Avatar
cptinjak
DO NOT put a metal floor jack directly on the composite spring when you lift it. Protect it with a chunk of wood at the least.
Old Sep 1, 2009 | 11:32 PM
kdeal's Avatar
kdeal
St. Jude Donor '09
I am guessing for the one inch drop mod, mainly just to make a c-5 appear more like a damn Batmobile. Naturally, which is why I am doing it. Probably wouldnt be too terribly costly to bring it to your trusted mechanic. Throwing her up on the lift and adjusting the bolts couldnt take more than a half hour. I may go that route, I hate being underneath those cars, no gaps anywhere, just a flat pancake maker for your head......I admit I am a wanny.
Old Sep 2, 2009 | 12:04 AM
Dennis Wilson
Good point, I should have mentioned that. I always used a folded rag on the spring when I was doing it.
Old Sep 2, 2009 | 01:22 PM
cptinjak's Avatar
cptinjak
Batmobile???
Think it would kill you LESS if it falls on you from a hoist or from a 1' jack stand? Proper lifting safety procedures are necessary no matter how you lift it.
(I admit, I dropped a car on my head once when a scissor jack broke as I was placing a jack stand. Just caught the pinch rail and I consider myself lucky to be alive, but this is no reason to NOT use jacks/jackstands. Just be safe!)
Old Sep 3, 2009 | 01:37 PM
ovrpar6's Avatar
ovrpar6
$100 bucks had mine lowered approx. 2in that way by a HP Performance
Old Sep 3, 2009 | 02:31 PM
hotwheels57's Avatar
hotwheels57
If you find the rubber bushings are vulcanized to the control arm, which won't allow the adjustment bolts to turn, try using your choice of lubricant (most use PB BLASTER) on the bushings and pry them off with a metal putty knife...
Old Sep 3, 2009 | 03:39 PM
Dream Tire's Avatar
Dream Tire
Mine are completely seized.
Gonna have to rip out the leaf
Fun fun
Old Sep 3, 2009 | 04:14 PM
Gideon's_Test's Avatar
Gideon's_Test
Before you pull the leaf try this:
If you’ve buggered the factory bolt) get a Craftsman bolt extractor kit. It looks like an impact socket, but has teeth that dig in to buggered bolts.
I combined this with a 1/2" drive impact wrench. Select a bolt extractor socket that is slightly smaller than the diameter of the bolt and tap it onto the bolt, then attach the impact and using very short squeezes of the trigger, loosen the bolt.
Once it had broken free, I used a ratchet to finish lowering it. I had to do this with my lowering bolts as they were seized. You'll have to remove the shock to get room to maneuver the impact drive into place.....
If you get ham fisted with the impact wrench, you may end up tearing the bushing from the leaf, but it's worth a try!
Old Sep 4, 2009 | 04:11 PM
TBH94's Avatar
TBH94
The bushing seems to want to turn with the stud. Is this normal?
Should the stud turn independent of the bushing? Do they seize together?
Old Sep 4, 2009 | 04:19 PM
FASST LN's Avatar
FASST LN
That is normal. The bushing should turn with the bolt. That is what makes turning the bolt difficult, because the busing wants to hold onto the spring and not turn.
Old Sep 4, 2009 | 04:31 PM
TBH94's Avatar
TBH94
Perfect. That is what I was wondering. I didn't want to turn it too far until I was sure.
Thank you!
Old Sep 6, 2009 | 02:20 PM
Gideon's_Test
There is some ambiguity with regards to the word "bushing" as it is used here in this thread. The bushing I was referring to is the steel bushing that is molded inside the leaf spring, essentially a nut.
The bushing FASST LN is referring to the the rubber bushing at the bottom of the lowering bolt. This bushing stick to the spring making turning the bolt difficult. Both "bushings" make lowering more difficult if seized...
Old Sep 8, 2009 | 11:21 PM
zdillon06's Avatar
zdillon06
Default question
So I cut part of the bushing off for the rear tires and I reduced the number of threads showing. This got me about 1".
ON the front side I brought the bolt up as far as possible. This got me about 1/4". I would like to get another 1/2" or so to come closer to matching the 1" on the rear.
How do I go about getting the other 1/2" on the front?
Old Sep 9, 2009 | 01:37 AM
Dennis Wilson
Cut 2 rings off the front bushings. I did it without taking it apart by jacking up the car, remove wheels, lift spring up with small jack with a rag under spring, to protect it I used a keyhole saw working from under the center of car. Each side took about 20 mins. Its kind of a pain but worth it IMO. For a point of reference the Wheel wells on my car are 26" from ground front & 27" in rear & body is 3 1/4th from ground front & 3 1/2" in rear. Been this way for 5 years now & 25000 mi. never been aligned Tracks perfect on fwy & tires wear even! Guess I`m one of the lucky ones as far as alignment is concerned. Hope this helps.
To Lowered on Stock Bolts??
