clutch res cleaning
Old Sep 1, 2009 | 06:13 PM
04Z06vette's Avatar
04Z06vette
Navigator
Default clutch res cleaning
I read the sticky and watched the video clip about changing out the clutch fluid. Does anyone know where to get the large hypodermic nedle like device to evacuate the old fluid cleanly? I hate the thought of using a turkey baster since it will probably leak hydraluic fluid all over the place.
Old Sep 1, 2009 | 06:31 PM
bartsky's Avatar
bartsky
Auto Zone...
Old Sep 1, 2009 | 07:26 PM
chris723@ptd.net's Avatar
chris723@ptd.net
walmart in auto sec
Old Sep 1, 2009 | 10:41 PM
LoneStarFRC's Avatar
LoneStarFRC
I have used a turkey baster numerous times and do not have any "leak" problem. Spread a number of paper towels around and under the mc.
Insert baster tip all the way down to the bottom, suck fluid in, and then when withdrawing it, immediately put your finger over the end as soon as it clears the top of the reservoir. Keep your finger over the end until you're over a close-by wide mouth jar/container and gently squeeze the fluid out. Repeat as necessary. I also keep a another separate container near with paper towels inside to put the baster in when not using. Empty mayonnaise jars are perfect. Just be careful where you set them so they're stable. Very easy actually.
Old Sep 2, 2009 | 11:41 AM
Fast Cop's Avatar
Fast Cop
Turkey Baster worked just fine for me. Just remember to clean it prior to giving it back to the wife or putting in back in the kitchen.
Old Sep 2, 2009 | 11:52 AM
Ranger's Avatar
Ranger
The end-to-end clutch fluid change process.
Syringe shown in the video is the MixMizer, available widely including Walmart, where it can be found in automotive on a pegboard near the gas cans. It costs about $3.
Ranger
Old Sep 2, 2009 | 06:28 PM
04Z06vette's Avatar
04Z06vette
Navigator
thanks for all the good ideas. I guess i didn't look hard enough
To clutch res cleaning
