5th and 6th gear grind
Old Sep 2, 2009 | 05:33 AM
chipsteak's Avatar
chipsteak
Default 5th and 6th gear grind
5th and 6th gears often grind when I'm upshifting at about 70 mph. I'm sure I have the clutch to the floor when it does this. If I shift slowly and very deliberately it doesn't grind as often. I don't have this problem with any other gear. Do my RPMs need to be higher when I go to 5th gear? Any thoughts?
chipsteak
Old Sep 2, 2009 | 05:36 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Synchros getting old and tired, old plastic fork pads worn out. Just a couple of ideas. Many times I have read changing the trans fluid to Royal Purple Synchromax helps if you care to try it. Darn sure cheaper than a good rebuild.
