Is there any difference between an auto and manual diff?
Old Sep 4, 2009 | 09:12 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Is there any difference between an auto and manual diff?
Aside from gear ratios, can I swap an auto trans diff into a manual car?
Old Sep 5, 2009 | 11:04 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Yes.
Old Sep 5, 2009 | 11:20 AM
Patches's Avatar
Patches
Realize that you'll need to remove the A4 diff seal plate from the old diff before installing it to the manual trans. The plate is only needed on the A4.
The A4 place
Plate still installed on the diff
Old Sep 5, 2009 | 11:58 AM
ljthe2nd's Avatar
ljthe2nd
The diff that comes standard with an A4 (2:73 axle ratio) is different than the diff that comes with an A4 with the performance rear end (3:15), or an MN6 or MN12.
Old Sep 5, 2009 | 03:42 PM
Fastguy's Avatar
Fastguy
I have a 3.42 in my 6 spd car. I bought a 3.15 rear because I burned up my diff. I swapped in an MN12 so with the tighter trans gear, the 3.15 shouldn't be a big change.
Old Jul 20, 2021 | 08:19 PM
Oswaldo Acuaheretik's Avatar
Oswaldo Acuaheretik
2nd Gear
What was your driving experience , making this swap?. im thinking on doing the same, for the same reasons that you
greetings!
To Is there any difference between an auto and manual diff?
