Hearing a noise with AC on
Old Sep 5, 2009 | 08:28 AM
03BlkZ's Avatar
03BlkZ
Default Hearing a noise with AC on
Yesterday I noticed a noise in my 03 Z06 when the ac was on. It was on start up and it was almost like a knpcking noise. It scared the **** out of me. Then I turned the AC off and it went away. When I got home I looked around and saw nothing obvious but every time I put the AC on I hear the noise. I did grab my AC tensioner and it has some side to side wobble. Could this be the cause? I will try to investigate further this afternoon!
Old Sep 5, 2009 | 08:40 AM
Old Rotor Head's Avatar
Old Rotor Head
If the sound isn't coming from under the hood. You may have a rock or something in your interior fan cage. Had that issue a few years ago, it's behind your glove box.
Old Sep 5, 2009 | 12:25 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Remember there are two tensioners, one for the main serpentine and one for the AC Belt. If you have a long screwdriver or a audible probe, put it on the case of the compressor while its running, with the other end on you ear and see if that is where its coming from.
To Hearing a noise with AC on
