What is 'keying' a crank?
Old Feb 19, 2002 | 07:25 PM
FarmerBob2001's Avatar
FarmerBob2001
Default What is 'keying' a crank?
I've seen this mentioned in some threads on superchargers. Just curious what it is exactly. Thanks.
Old Feb 19, 2002 | 07:43 PM
Patches's Avatar
Patches
Default Re: What is 'keying' a crank? (FarmerBob2001)
A keyway (slot) is cut into the crankshaft and a matching keyway is cut into it's mating component (can be a sprocket, etc.). A key, often just a small square or rectangular bar, is inserted into the keyway in the shaft and the mating component is assembled onto the shaft, sliding the matching keyway over the protruding part of the key. This rotationally locks the two components together. In otherwords, when torque is applied to the shaft, it's transferred to the mating component, causing it to turn synchronously. The key prevents slippage between the two components, which in power transfer can be detrimental or even disastrous, especially when critical timing is required.
Ed
Old Feb 19, 2002 | 08:49 PM
GraveDigger's Avatar
GraveDigger
Default Re: What is 'keying' a crank? (Patches)
Does this mean to properly install a suercharger you must tear your engine apart to do this??????????? :confused:
Old Feb 19, 2002 | 09:03 PM
boblackhardtop's Avatar
boblackhardtop
Default Re: What is 'keying' a crank? (GraveDigger)
They can do it w/o removing engine.
Old Feb 19, 2002 | 09:21 PM
aces's Avatar
aces
Default Re: What is 'keying' a crank? (boblackhardtop)
HOW????
Old Feb 19, 2002 | 11:43 PM
ZO6LS6's Avatar
ZO6LS6
Default Re: What is 'keying' a crank? (aces)
One way is by drilling a hole into the crank, & the balancer while still on the vehicle.........
The keyway & key, need not be rectangular.......you just need a STOP for the balancer so it will not SLIP past the original timing location.
To What is 'keying' a crank?
