need help trouble shooting pass mirror
Old Sep 6, 2009 | 12:01 PM
Digmo's Avatar
Digmo
Default need help trouble shooting pass mirror
motor function. Problem is pass mirror will not move up or down. In or out function is normar as is operation of driver side mirror. I did remove pass mirror glass to confirm that jack screws for up or down are not turning when pressing the correct control buttons.
Looking for help to trouble shoot and fix problem.
Thanks in advance
Old Sep 6, 2009 | 01:42 PM
GeorgeZNJ's Avatar
GeorgeZNJ
St. Jude Donor '08-'09
Thanks in advance
Make sure the glass in FIRMLY pressed into the pivot. I had this problem when replacing my glass after breaking it on a track cone.Other than that, I do not know.
Old Sep 6, 2009 | 09:17 PM
byronhunter's Avatar
byronhunter
Monitor the voltage on the two wires to the UP/DOWN motor with a volt meter. That will tell you if the motor is bad, or the problem is in the DCM or associated wiring.
Old Sep 6, 2009 | 09:24 PM
byronhunter
To need help trouble shooting pass mirror
