C-5 Auto Trans help
Old Sep 8, 2009 | 03:51 PM
vettman6's Avatar
vettman6
Default C-5 Auto Trans help
Transmission Experts . Found fault code PO742 Torque converter solenoid stuck. Car is A 99 And has a aftermarket torque converter. Not sure wich one. Erased code will check again in a week. Any idea Does it require transmission removal or just valve body work.
Old Sep 8, 2009 | 03:59 PM
kh400's Avatar
kh400
The solenoid that controls T/C lockup is located in the valve body , I believe. I think it can be replaced with the trans in the vehicle. Good luck!
