LS2 90 TB Flipped?
Old Sep 9, 2009 | 02:03 PM
zeevette's Avatar
zeevette
Default LS2 90 TB Flipped?
I've got a FAST 90 w/ LS2 TB, which, of course, has the actuator pointed to the pass. side, like all LS2s-up. I just ordered a SC kit, and I have to flip the TB 180 deg., which will interfere with the power steering reservoir. Does anybody have experience moving the PS bracket to clear? Any help/advice would be appreciated. Dave.
Old Sep 9, 2009 | 02:13 PM
lucky131969's Avatar
lucky131969
Post in the FI section, the Maggie guys have to do it.
Old Sep 9, 2009 | 03:03 PM
glennd's Avatar
glennd
I changed my ls6 manifold to a fast 90/90. I have a procharger. Yes the TB has to be rotated 180*. I then put the power steering reservoir on 2.125" spacers. I may have also cut the bracket holding the reservoir I don't exactly remember. I got the longer bolts and stand-offs fom McMaster Carr I think I stacked 1.00" with 1.125" spacers. It has been holding fine for a year. You will also need a longer piece of bent hose for the bottom of the reservoir.
Old Sep 9, 2009 | 07:19 PM
zeevette's Avatar
zeevette
I guess I have trouble visualizing the end result... What direction is the res. moved? Up, forward, both? What about pulley alignment, and belt size? Andy said I'd be better off trading my FAST90 setup for a stock LS6 setup, because with boost, the FAST isn't really relevant anymore.
Old Sep 9, 2009 | 08:06 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
It would push the reservoir forward.
The reservoir is a separate component from the pump (connected to each other with a short pc of rubber hose), so no pulley or belt changes needed, the pump itself wouldn't move.
Old Sep 9, 2009 | 08:11 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
An easier alternative may be to just pick up a billet body 90mm TB...which uses all the stock LS1 electrics and motor.
Something like the Nick Williams, LG G2 (these two kinda hard to find these days), or the Rev Xtreme.
Old Sep 9, 2009 | 08:25 PM
glennd's Avatar
glennd
The reservoir is moved forward.
Old Sep 9, 2009 | 09:18 PM
Brandon619's Avatar
Brandon619
It is perfectly fine to flip the LS2 TB. I've been running mine this way for 2 plus years with no issues. If you look closely you can see my spacer for the power steering res. under the TB.
Old Sep 9, 2009 | 11:56 PM
zeevette's Avatar
zeevette
Thanks. I took a look when I got home, and I'll just keep the FAST setup, and modify the res mounting. Appreciate the feedback.
I also discovered I have to get rid of my Meziere EWP, and I don't know if my Powerbond UD pulley is gonna work, either. Should've done the SC earlier, I guess.
Old Sep 10, 2009 | 12:28 AM
intoc6s's Avatar
intoc6s
You won t use the Underdrive pulley. It would slow down your Supercharger too much to make enough boost. You ll need your stock damper or a good aftermarket.(non-UD)
Old Sep 10, 2009 | 02:48 PM
zeevette's Avatar
zeevette
CRAP! Oh well, looks like somebody's gonna pick up a nice cheap pulley. Any suggestions on aftermarket ones that aren't UD, because I don't want to put the stock one back on. It's going to be pinned, and there's been so many failures of stock pulleys, that I won't risk re-using my old stocker.
Old Sep 10, 2009 | 03:23 PM
sami85L98's Avatar
sami85L98
Hey zeevette, if u would like to swap my TPIS 90mm TB with yours LS2 90mm TB and its harness than let me know. Its also ported and comes with electronics IAC stepper motor and TPS sensor. LMK.
To LS2 90 TB Flipped?
