Fort Worth pro ear needed
My problem is I hear what I feel is a driveline balance situation but since Ive never had a forged setup with all those other goodies listed I dont know if what I am hearing is normal.
To me the clutch is great, no chatter, not hard to shift...a little touchy but its new...I just hear a noise that sounds strange under load....let off the gas or even depress the clutch and its gone.
I have yet to do a new 4 wheel alignment, tires are brand new and balanced, and all the fluids...trans,oil, and diff are perfect. We did find that someone jacked up the brake line causing it to touch the boot coming from the diff and pretty much gouged it to the point that grease is flinging out and the brake line is almost cut open but we moved it to not touch anymore so I know thats not it.
Anyway I just want an experienced ear to tell me that I either have a problem or to quit whining like a bitch...LOL
Hurst, Euless, Bedford, Ft Worth would be great and I will come to you and take you for a ride to let you hear.
Jerry
Jerry
You did go with the Fidanza dual disc clutch, right? Impressions?
Im having idle search issues that need to be addressed but I dont know if its because of the 610 lift on the cam, aluminum flywheel, underdrive pulley or combination of all of it but I sure hope its not the flywheel as I would rather do a cam change than to pull that flywheel out.
