Headlight Problem
Old Sep 9, 2009 | 11:30 PM
Z06_KYLE's Avatar
Z06_KYLE
Default Headlight Problem
I need to purchase a headlight motor control module. Where can I buy one and how much? Thanks in advance
Old Sep 9, 2009 | 11:45 PM
lucky131969's Avatar
lucky131969
Originally Posted by Z06_KYLE
I just registered here and I was amazed with the knowledge of this site and I have a question for you all. So I recently purchased a 02 Z06 with non-pop lights, the stock headlight assembly was in a box in the back of the car. I thought it would be a simply task to change them out. So I removed the non-pops and installed the stockers and know the lights won’t come up or down. I don’t think I need the brass gear because I don’t hear any grinding. I checked the fuses and none are damaged. Oh yea the actual lights work fine. Thanks in advance
It the headlight control module still there? Hooked up?
Old Sep 10, 2009 | 12:04 AM
Z06_KYLE's Avatar
Z06_KYLE
Thank you lucky thats the problem there is nothing there no control module Thank You again
Old Sep 10, 2009 | 12:05 AM
Z06_KYLE's Avatar
Z06_KYLE
Do you know where I can purchase a control module from?
Old Sep 10, 2009 | 12:50 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Control module, corvette
97-04 $281.09 $219.25 from Gene Culley
Old Sep 10, 2009 | 03:02 AM
Z06_KYLE's Avatar
Z06_KYLE
Thank you for the info
Old Sep 10, 2009 | 07:19 AM
lucky131969
Check the parts section for cars parted out....
Old Sep 10, 2009 | 09:53 AM
c3andc5's Avatar
c3andc5
Ecklers has them for $199.99 (new) and $139.99 (rebuilt)
Old Sep 14, 2009 | 03:14 AM
Z06_KYLE's Avatar
Z06_KYLE
Ok I got the control module pluged in and still no lift. Is there some sort or resetting you have to do after install?
Old Sep 14, 2009 | 10:55 AM
dgrant3830's Avatar
dgrant3830
The only other item in the setup is the headlamp switch.
Old Sep 14, 2009 | 12:19 PM
byronhunter's Avatar
byronhunter
Check fuses # 3&4 underhood.
Old Sep 15, 2009 | 08:41 PM
Z06_KYLE's Avatar
Z06_KYLE
I checked my fuses and cleaned all grounds and still nothing, but I think I found the problem. I cracked open the control module and found it was full of water.
Old Sep 15, 2009 | 08:48 PM
dgrant3830's Avatar
dgrant3830
I thought you had replaced it already? Full of water would indeed cause things to not work as designed.
Old Sep 15, 2009 | 09:03 PM
Z06_KYLE's Avatar
Z06_KYLE
No I was going to replace it then I found at the bottom of the bumper by the horn, thats to the previous owner.
Old Sep 15, 2009 | 09:04 PM
Z06_KYLE's Avatar
Z06_KYLE
thank you all for the help
To Headlight Problem
