Stereo Power cutting out???
I just removed my STS Turbo system, and did a Cam swap while I had the engine compartment apart. The new cam is in, car is running great, but now the Stereo keeps blacking out.
The stereo will work for a minute or two, and then it cuts out, goes blank for a few seconds, and the lights come back on with the clock at 1:00. It will work for a few more minutes and then do the same.
It seems like a ground issue, but I can't seem to find any loose ground connections. I haven't pulled apart the ground connectors to see if there is any corrosion yet.
Does anyone know exactly which grounding point the stereo wiring grounds to? Any other ideas?
Please help!!
G
