New tires, now problems?
Old Sep 11, 2009 | 08:51 PM
Nver2loud's Avatar
Nver2loud
Default New tires, now problems?
Hey guys, i bought some new tires and had them mounted today. car is a 2000 m6 coupe, had 335/30 r18 on the rear and i bought 315/30 r18 to replace, the tires were alot cheaper for being a little bit smaller. The fronts are 285/40r17 if that matters. I left the shop and now i get a traction control message on the DIC with even a little bit of spin which was normal but it stayed on longer than normal. About a 1/2 mile down the road is a large hill, and it curves around and while going up that hte traction control message went on and stayed on all the way up and down the hill until the next curve, total time about 1/4 mile, and it cut me down to about 20 mph. Is this just a coincidence and there is a different issue, or does it have something to do with my new tires?
Thanks in advance!
Old Sep 11, 2009 | 09:02 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Rule 1 when altering tire sizes...Always keep the rear tires taller than the fronts.
You picked a very short rear tire, and have a rather tall front tire. Bad combination.
Traction Control works by monitoring the front and rear wheel speeds. When it detects the rears turning faster than the fronts, TC engages and cuts power. Tire diameter obviously affects that wheel speed "logic" as the hub sensors report.
Your two options at this point are to:
Size your tires so that the rears are taller than the fronts, or...
Turn off Traction Control after you start the car.
Old Sep 11, 2009 | 09:41 PM
Nver2loud's Avatar
Nver2loud
This sucks....So even if i had almost the same size tire before, i was just getting lucky pretty much?
Old Sep 11, 2009 | 10:01 PM
rebelheart's Avatar
rebelheart
You were prob right on the edge with your old tires,the new smaller tires put you past!
Old Sep 11, 2009 | 10:08 PM
Nver2loud's Avatar
Nver2loud
But they are smaller width wise...I just went out and measured and sure as $hit, the rears are shorter than the fronts...I just looked for tires and it also seems that finding a smaller tire for my front is fairly impossible, as I beleive i would need something in the range of a 275/35 r17. Soooo, does anybody want to buy some very good shape 285/40 17?
Old Sep 12, 2009 | 12:17 AM
pcbunn's Avatar
pcbunn
Does anyone know how much taller the rear must be to avoid the DIC message. I'm getting ready to mount 275/35/18's on the front and 305/30/19's on the rear. The diameter of the fronts is 25.6 and the rear is 26.2 for a difference of only .6" larger in the rear. Is this enough to avoid having a problem? Thanks for any advice.
Old Sep 12, 2009 | 12:35 AM
byronhunter's Avatar
byronhunter
Consusis is 1/2 inch from what I've read here. It probably varies car to car, that's just my opinion. (not worth much) I ran a set for about a week, 1/4 inch taller in the rear, no codes. YMMV
Old Sep 12, 2009 | 12:46 AM
pcbunn's Avatar
pcbunn
That's good to hear. Thanks for the info.
Old Sep 12, 2009 | 01:12 AM
striper's Avatar
striper
You should be able to find a 275/40 for the front though it might not be short enough. You should run a 35 series tire in the rear. 1/2" difference is enough front to rear diameters.
Old Sep 12, 2009 | 01:20 AM
pcbunn's Avatar
pcbunn
According to the tire calculator I get .6" difference running a 275/35/18 front and a 305/35/19 rear. If .6" is enough difference I'd like to stay with the 35 series in the front to keep the visual sidewall measurement as close as possible. I think they look better that way.
Thanks for your comments.
Old Sep 12, 2009 | 06:26 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Rule of thumb used to be one inch from front to rear. We have found out over the years some cars can run the same size front and rear and not have a problem while others go crazy.
Too bad you had to find this out after you purchased new tires.
Old Sep 12, 2009 | 08:26 AM
RSchleder's Avatar
RSchleder
PCBUNN-- I have the exact size wheels and tires on my 2000 vert that you are running. Had them for 2 years--all is well!
Old Sep 12, 2009 | 09:52 AM
lucky131969's Avatar
lucky131969
Hmmmm.....not soo sure this logic applies here. I must know a dozen guys(including myself) running stock size up front (245/45/17) and 315/30/18 drag radials. By your suggestion, this should cause a significant problem, because there is even more of a disparity in the height(aspect ratio) between front and rear. In all cases, no problems, including myself.
Old Sep 12, 2009 | 09:58 AM
Dream Tire's Avatar
Dream Tire
285/40R17 OD26.0
315/30R18 OD25.4
335/30R18 OD25.9
Thats totally off. Your rear tire needs to be around 26.8 - 27.0
You should have had an issue with the 335s as well. On the 18 inch wheels you need to up the profile by 1 size. From a 30 to a 35
Rod
DreamTire
Old Sep 12, 2009 | 10:12 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
You do realize the 245/45/17 is a shorter tire than the 285/40/17 the OP is running on the front?
Aspect ratio is the sidewall dimension expressed as a percentage of the tire's width.
40% 0f 285 is a greater value that 45% of 245 is.
In this example, his 285/40s are about 3/8" taller than your front tires.
On paper, the 245/45/17 and 315/30/18 combo should also cause occasional false TC engagement...but if you find it's working for you, then consider yourself lucky. (Oh wait, seems you already do )
Old Sep 12, 2009 | 10:16 AM
Dream Tire's Avatar
Dream Tire
Old Sep 12, 2009 | 11:12 AM
K RIPPER's Avatar
K RIPPER
Interesting thread,learned something new today thanks all!
To New tires, now problems?
Old Sep 12, 2009 | 11:24 AM
lucky131969
I was wrong.....the OP's tires are indeed taller than mine. With as many combo's as I've seen like mine, I don't consider myself lucky, I consider it average....
Old Sep 12, 2009 | 11:41 AM
vetterdstr's Avatar
vetterdstr
Originally Posted by Dream Tire
285/40R17 OD26.0
315/30R18 OD25.4
335/30R18 OD25.9
Rod
DreamTire
Old Sep 12, 2009 | 11:44 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
The other thing to consider is how many folks running drag radials actually leave TC on all the time. That's all it takes for this to become a non-issue.
