Gauge install help...
Old Sep 12, 2009 | 05:28 PM
11SECSS's Avatar
11SECSS
Default Gauge install help...
Which wire do I splice into at the ECU for the A/F?
Also any what wires do I splice into for the fuel pressure gauge?
Thanks!
Old Sep 15, 2009 | 06:57 PM
11SECSS's Avatar
11SECSS
Ttt
Old Sep 19, 2009 | 12:15 PM
11SECSS's Avatar
11SECSS
Ttt
Old Sep 19, 2009 | 01:18 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Your fuel pressure gauge should just have a sending unit that you can tap into at the rail and a 12v key on hot wire and a ground wire.
The A/F ratio gauge will have the same hot and ground wires along with a wideband O2 sensor
To Gauge install help...
