C-5 clutch spring broken
Old Sep 12, 2009 | 09:41 PM
rjm5's Avatar
rjm5
Default C-5 clutch spring broken
my C-5 clutch starting making a pingy noise when operating; it looks like one side of a double spring has broken. What is involved in replacing it and any idea on cost? Thank you!!
Old Sep 13, 2009 | 02:18 AM
Last C5's Avatar
Last C5
The spring is your clutch assist spring. (Helps push the clutch in so your clutch will be a bit stiffer without it. ) You don't need it. Take out both halves of the broken spring so it doesn't get hung up just when you don't want it to and you're set. Some people remove them as added insurance against the sticky clutch syndrom. If you do decide you need it, they're available at your dealership and reasonably cheap.
Old Sep 13, 2009 | 06:21 AM
rjm5's Avatar
rjm5
Thank you for the valuable information on my clutch spring, I'll remove it. Have a great day! Jim
To C-5 clutch spring broken
