Front Marker Bulbs
Old Sep 13, 2009 | 10:47 AM
goodref's Avatar
goodref
Cruising
Default Front Marker Bulbs
Can someone tell me the correct bulb number/size for the front marker lights (the orange one on all the time) on a C5-2002? Thanks.
Old Sep 13, 2009 | 09:15 PM
Nate B's Avatar
Nate B
Its an amber 3157
Old Sep 13, 2009 | 09:34 PM
SaberD's Avatar
SaberD
you should get the switchback led towers from JWMOTORING. i get compliments on mine all the time. however you will need to buy a hyperflash fixer harness. the towers can be bought here: http://shop.jwmotoring.com/product.s...9&categoryId=4
Old Sep 13, 2009 | 09:39 PM
Oldvetter's Avatar
Oldvetter
3157 NAK is what is called for, but you will have problems finding that bulb. I once paid $10 at a dealer for one, never again.
You can use any 3157 yellow long life bulb. You need a long life because the turn signal filament is used for "daylight driving lights" and any other bulb wears out quickly. 4157NALL is the current replacement bulb.
If you are breaking bulbs after washing your car or driving in the rain, you have a hole in your light assembly. This is caused by the heat due to the turn signal filament being used for "daylight driving lights". You can fix this with sealant.
(corrected to read "turn signal filament is used. . .")
Old Sep 13, 2009 | 09:40 PM
lionelhutz's Avatar
lionelhutz
4157 amber in color. The 3157 is not rated for continous duty though in most cases it likely does not matter (same bulb with a different number).
Peter
Old Sep 13, 2009 | 09:42 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by Oldvetter
both filaments are used for "daylight driving lights"
Not true, the turn signal filament is used.
Peter
Old Sep 13, 2009 | 10:08 PM
byronhunter's Avatar
byronhunter
Peter
Old Oct 7, 2010 | 02:19 PM
rmarks's Avatar
rmarks
My front turn signals use an amber 4157NA. My manual says the 3157NA. The marker light is a smaller clear bulb; the manua lsays it's a 194NA
Old Oct 7, 2010 | 05:28 PM
Nate B's Avatar
Nate B
Youre a little over a year late on this thread buddy
To Front Marker Bulbs
