Anyone with a Good HPT Config File
Old Sep 13, 2009 | 08:44 PM
MVP'S ZO6's Avatar
MVP'S ZO6
ISIS SUCKS FAT CHOAD
Default Anyone with a Good HPT Config File
Hey guy's just completed my cam and head swap. The car wont stay running. I'm running open headers at the moment. I need a good HP Tuners configeration file so I can start data logging and trouble shooting. anyone? my email is michael.vanparis@yahoo.com
Old Sep 13, 2009 | 10:46 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
If you have HPTuners, check out the repository on their website with hundreds of tunes loaded up.
For starters, bump up your idle speed and idle airflow, that should get it running long enough to start logging.
And without knowing your level of expertise, if you don't know what the above two values are, than you should probably have it tuned by an expert. Depending on the size of cam, tuning can be very tricky.
Old Sep 14, 2009 | 01:30 AM
MVP'S ZO6's Avatar
MVP'S ZO6
I have a good base tune I need a configuration file. i.e. a good datalogging file.
Old Sep 14, 2009 | 04:46 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
You can look in HPtuners Help section to learn how to make one. I'll send you one though.
Sent you an email. Reply to that email and tell me where you got that " base tune" from. Working nights this week, so I may answer emails at odd hours.
Old Sep 14, 2009 | 05:10 AM
MVP'S ZO6's Avatar
MVP'S ZO6
Awesome man. Thanks I just posted in my other thread if you get a chance to look at it.
Old Sep 14, 2009 | 08:17 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
What's your set up. Guys might have a close tune already.
Remember NOT to upload someone elses tune in your car. You have to cut and paste their cells into your file
Old Sep 14, 2009 | 06:07 PM
MVP'S ZO6's Avatar
MVP'S ZO6
yup copy and paste is the way it is.. anyway my mods are as follows
Cam is a Custom Lunati grind
Int. Exh.
Valve Lift .578 .592
Lobe Lift .340 .348
Adv Dur. 284 292
Dur @ .050 233 241
Center Line 110 118
Timing @ .050 tappet Lift
BTDC 7 ABDC 47 BBDC 59 ATDC 3
Cylinder heads are stock LS1 806 castings. Ported out. Milled .025
2.08/1.60 valves, spring and titanium retainers...
flow specs on the heads are as follows.
Int CFM 28" H2O Exh. Flow CFM Exh/Int flow ratio Percent
.200 120 .200 106 88
.300 188 .300 144 76
.400 240 .400 182 76
.500 275 .500 206 75
.600 295 .600 223 75
Smith brothers push rods.
stock GM AC Delco lifters
Ford "Green Top" 42LB/HR injectors
new oil pump and timing chain
Stock Rockers/
LS6 intake manifold.
stock GM MLS head gaskets
I have a pretty decent tune I compaired it with a tune that matched my set up the most and the tunes were pretty close.
Old Sep 15, 2009 | 01:02 AM
nj02vette's Avatar
nj02vette
You say you have a good tune, but the car won't stay running
Before you can try any sort of logging, you have to get it stable enough to run logs, and that means running long enough to warm up, get the wideband to operating temperature and let the STIT and LTIT's settle in.
Old Sep 16, 2009 | 12:46 AM
MVP'S ZO6's Avatar
MVP'S ZO6
The car is running great and I'm a dumb ***. ok here it goes. I pulled a copy of the stock tune off my car before I even began the heads, Intake and cam swap so I could send it to a respected tuner on these forums who provided me a base tune for my H/I/C swap. To make a long story short. I thought I put the H/I/C tune on the car but after checking just to make sure, it became apparent to me that I did not. I left the stock tune on the PCM. After putting the H/I/C tune on there the car runs like a champion. Well, it runs well enough to drive it around and up to the dyno for some tuning.
Heres a short video clip of my car at idle. no real tuning yet.
To Anyone with a Good HPT Config File
