Higher stall torque converter how-to ?
Old Sep 18, 2009 | 10:56 AM
dancin1's Avatar
dancin1
Default Higher stall torque converter how-to ?
Hey folks, what is really involved in changing the torgue converter ? Can it be done on jackstands ? What has to be dropped down ? What else should be changed ? I do plan on installing a transmission cooler, also. Any help would be appreciated ? Thanks.
Old Sep 18, 2009 | 02:53 PM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/342.htm
Old Sep 18, 2009 | 06:01 PM
dancin1's Avatar
dancin1
Thanks Mike, and I see what you did changing the gears, but, just the torque converter...I know you changed yours, remember reading the article, but, can't find it now and don't remember. Could a regular good transmission shop do this without many problems ?
Old Sep 18, 2009 | 09:07 PM
Patches's Avatar
Patches
Here you go - I changed gears and TC and installed headers and a tranny cooler at the same time.
http://forums.corvetteforum.com/c5-g...mega-pics.html
You can do it on jackstands as long as you provide enough clearance to pull the rear crossmember out the back. Also, you can pull the TC and tranny/diff without pulling the torque tube as I did.
Old Sep 19, 2009 | 11:08 AM
corvettebob1's Avatar
corvettebob1
No!
Why don't you give Geoff a call at Next Level Performance 407-869-7223 he's in Altmont Springs not far from you.
To Higher stall torque converter how-to ?
