swar bar installation
Old Feb 21, 2002 | 01:28 PM
mhefner's Avatar
mhefner
CI-3 Show Winner
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Default swar bar installation
Quick question:
When install swar bars should the suspension be loaded? or does it matter?
Old Feb 21, 2002 | 01:34 PM
motoracer's Avatar
motoracer
Default Re: swar bar installation (mhefner)
When I did mine I jacked up the front since it was too low to get under and then I also jacked up the rear just to make things easier. But if you have a lift, I don't think you will have a problem unless you unload one side of the suspension and not the other.
Old Feb 22, 2002 | 07:25 AM
C5 Frederik's Avatar
C5 Frederik
I did mine loaded. There is a rubber hose around every end of the endlink. This will be quenched a little bit when mounted unloaded.
Could I describe it well?
Frederik
Old Feb 22, 2002 | 09:02 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In VI Veteran
It doesn't matter for you could do it either way.... I have done it both ways without any issues...
Nick
Old Feb 22, 2002 | 01:17 PM
daveydc5's Avatar
daveydc5
It doesn't matter. Even with the chassis mount bolts torqued to spec you can roate the bar by hand. Combine that with the spherical endlinks and the bar will settle into place without resistance.
Old Feb 22, 2002 | 02:58 PM
MySea6's Avatar
MySea6
Yup, loaded or not doesn't really matter with stock endlinks.
To swar bar installation
