dic comes up low oil
Old Sep 19, 2009 | 10:29 PM
filsvet's Avatar
filsvet
Default dic comes up low oil
what will low oil level mean on the dic. I check the fluid levels and its fine. Does this code have to do with any other fluid level other then motor oil like trans fluid it is and automatic and that cant be check like motor oil any sugeestion this is on a 98 c5 all levels are full, but the dic keeps coming up low oil level can it be the transmission fluid please help.....
Old Sep 20, 2009 | 01:30 PM
filsvet's Avatar
filsvet
Thank you so much for your input.I tripple check the oil level and it's full my next step is to look into the sensor will update after I check that out.Thank you....
