Traction Control
Old Sep 20, 2009 | 09:59 AM
marty12's Avatar
marty12
Default Traction Control
I used the search feature and havent found the answer to my question. What does the traction control feature do. The previous owener advised to leave it on. I noticed that in wet conditions when the tire spins a little the display reads traction control activated.
Old Sep 20, 2009 | 10:05 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
There is good description of the system and explanation on how to use it in the owner's manual. If you do not have one, you can download one from multiple sources on-line.
Old Sep 20, 2009 | 10:06 AM
timemender's Avatar
timemender
Keeps the drive wheels from excessive spinning to control traction.
Old Sep 20, 2009 | 10:17 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The traction control system works by comparing front and rear wheel speeds.
When wheelspin is detected (rear wheel speeds become faster than front), traction control engages, and applies rear brakes, as well as commanding the PCM to drastically retard spark timing, thus sharply cutting engine power.
Once the rear wheels have established traction again, power is restored, and things are back to normal.
In theory, it's great. In actuality, it's a buzzkill.
Many find the TC is too intrusive, cuts too much power, and remains active too long, not good things when the goal is to go fast.
Someone with mediocre reaction skills can usually better manage the throttle pedal when the wheels do begin to let loose, and correct it without such a drastic power loss.
To Traction Control
