Vette DIED Need Help?
Old Sep 22, 2009 | 04:30 PM
ziddo52's Avatar
ziddo52
well I know im getting fuel up to the fuel rails at least.. took the cap off of rail and pushed pin... fuel shot out.. as far as the spark.. still unsure however i dont have anyone to help with that until the morning.. being that i cannot start and look at plugs at the same time... If you have another way, please let me know..I will try it....Thank you for your help it's greatly appreciated..
Old Sep 22, 2009 | 04:38 PM
lucky131969's Avatar
lucky131969
First, you need to ensure the fuel pump is even priming. You will hear it come on for two seconds when the key is turned to the RUN position. Having fuel squirt from the schrader valve does not mean you have the right pressure. You need to install a gauge at the rail.
You also never responded to 8vette7's question regarding the security light. Is it flashing or not?
Old Sep 22, 2009 | 04:46 PM
ziddo52's Avatar
ziddo52
sorry I must have missed that post... Security is not flashing unless the Door is open... And Yes I can hear the Fuel pump prime when key is turn on... I will go out a buy a fuel pressure guage right now...
Old Sep 22, 2009 | 04:50 PM
lucky131969
Does your friend have one? Wait for him to help with the spark check first. If you don't have spark, game is off. A pressure gauge is inexpensive though, and great to have in your tool box. Also, make sure he has a Multimeter.
Old Sep 22, 2009 | 05:16 PM
ziddo52's Avatar
ziddo52
Okay.. went out and purchased a fuel pressure Guage... installed it.. turn key to run position heard the fuel pump prime.. fuel pressure guage read 60PSI
Old Sep 22, 2009 | 05:17 PM
ziddo52's Avatar
ziddo52
I have a multimeter... where should i check for spark?
Old Sep 22, 2009 | 05:36 PM
lucky131969
Excellent, and I assume no bleed down?
Old Sep 22, 2009 | 05:38 PM
ziddo52's Avatar
ziddo52
correct! where you do want me to check spark? one of the wires to ground? or is there a specific place on the vettes?
Old Sep 22, 2009 | 05:46 PM
lucky131969
I'll PM you my number...much to discuss.
Old Sep 22, 2009 | 06:51 PM
lucky131969
Ok Mark, per our conversation, here's what we know is good:
1) Ignition relay is closing with the key in the on position
2) 12 volts at PCM minifuse #16
3) 12 volts at the injectors
4) 12 volts at the ignition coils
5) 0.5 ohm ground at the ignition coils(indicates G107 is good)
6) Fuel pump runs - 60 psi at the rail with no bleed down
Below is the location of the crankshaft positon sensor. It is located aft of the starter. I'll look for a procedure, but checking for spark will point us in the that direction if there is none. If there is anyone you know with a scanner capable of reading RPM, it would be good to have, because the RPM reading on the scanner will be dead if the sensor(or wiring) is an issue. It's probably not a timing chain, since you only have 20K on the motor, but based on your description....backfire and shutdown, it's exactly what happened to me before(not on a vette).
Old Sep 22, 2009 | 07:36 PM
ziddo52's Avatar
ziddo52
Thank you so much for your help Lucky... I now at least feel like we're getting close to resolving this issue.. thanks.. at this time I have the car jacked up and battery on charge.. Hopefully my buddy comes by in the am so we can check spark..
Old Sep 28, 2009 | 09:41 AM
ziddo52's Avatar
ziddo52
Okay Lucky so here's what i've done thus far..
I have checked spark and getting good spark.. I then replaced the Crank shaft sensor and no luck... still no start... Now I do remember you asking if there was any bleed down from the fuel pressure.. at the time i was unsure.. but i will say that there is no bleed down when the unit is actually priming.. however once the prime stage is complete the pressure will bleed down... is this normal.. the only reason i'm asking is because I did read a thread saying that someone had good pressure (60PSI) at the rails and it ended up being the fuel pump... What are your Thoughts?
Old Sep 28, 2009 | 09:44 AM
  #33
ziddo52's Avatar
ziddo52
I will post the procedure for changing out the crank shaft sensor if no one has already... my case was a little different because I have Long Tube headers.... so I actually had to remove the header on the passenger side so I could access the starter which also needed to be removed.. once the header and starter are removed the crankshaft sensor is right there and easily accessible from underneath the vehicle.
Old Sep 28, 2009 | 09:49 AM
  #34
lucky131969
How fast does the pressure bleed down?
Old Sep 28, 2009 | 09:59 AM
  #35
ziddo52's Avatar
ziddo52
it begins about 10-15 seconds after priming stage is complete
Old Sep 28, 2009 | 10:02 AM
  #36
lucky131969
That doesn't tell me anything bro. "how fast" means: how many psi loss per minute.
Feel free to give me a call.
Old Sep 28, 2009 | 10:40 AM
  #37
ziddo52's Avatar
ziddo52
I'll give you a buzz this evening while the fuel pressure guage is on the fuel rails...
To Vette DIED Need Help?
Old Sep 28, 2009 | 11:01 AM
  #38
lucky131969
PM sent.
Old Sep 29, 2009 | 08:50 PM
  #39
ziddo52's Avatar
ziddo52
Okay everyone.. I can not express my thanks enough.. with your help I was able to isolate why the car won't start.. It seems as though I broke the timing Chain at minimum.. I will be pulling the motor this weekend, will place on motor stand and start tearing down the block... If I find any other issues i will post and to what was found.. Once again thanks for your help...
Ziddo
Old Sep 29, 2009 | 09:08 PM
  #40
lucky131969
Mark,
Per our conversation, considering this happened at high rpm, those heads have to come off to inspect the valves and pistons. When you finally get it torn down, pay particular attention to the security of the cam retainer plate. I can't help but wonder if it walked due to the bolts being left loose when you had the cam swapped.
