Need a Driver's Side Mirror
Old Sep 22, 2009 | 01:53 PM
newgene's Avatar
newgene
Default Need a Driver's Side Mirror
I cracked mine during the re-install process. It appears the glass is backordered through GM. Anyone have any other ideas of where to get one? I tried to order one from GMPartsDirect, but it is on backorder. The part number is 12530715.
Any suggestions?
Old Sep 22, 2009 | 02:07 PM
redrckt97's Avatar
redrckt97
if its just the glass part that is broken, a lot of glass co.s
will cut you one - Binswanger is one in Houston - but likely some wherever you are.
Old Sep 22, 2009 | 02:52 PM
newgene's Avatar
newgene
It is just the glass, but it has the heater elements traced on the backside. I don't even know if they work, to be honest, but I figured I would get the original.
Old Sep 22, 2009 | 03:03 PM
chaase's Avatar
chaase
St. Jude Donor '12
Any suggestions?
I forget the name, but there is a forum vendor that sells used parts. He might be able to get you replacement glass.
Old Sep 22, 2009 | 03:25 PM
newgene's Avatar
newgene
I was able to order it new from GMPartsonline.net. So, I no longer need the mirror.
Thanks, everyone.
To Need a Driver's Side Mirror
