Ventilation System
Old Sep 22, 2009 | 07:47 PM
1jetjock's Avatar
1jetjock
Default Ventilation System
Hello Forum members:
I have a real bummer of a situation: my 2002 C5 has been in storage this summer and a mouse has taken up residence in the ventilation system - namely in the motor fan assembly. I want to know how big a nighmare I can anticipate accessing the fan/motor. Is it a job that a weekend mechanic could takle or is it something better left to a pro? How many hours involved?
Thanks!
1jetjock
Old Sep 22, 2009 | 08:27 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Very easy job, should take you about an hour. Its under the dash on the passenger side.
Old Sep 22, 2009 | 08:32 PM
torkman15's Avatar
torkman15
I'm interested too, is there a filter in there to change?
Old Sep 22, 2009 | 08:34 PM
Swt_86's Avatar
Swt_86
Nope. No filter in these cars at all.
Old Sep 22, 2009 | 09:55 PM
byronhunter's Avatar
byronhunter
Blower Motor Replacement
Removal Procedure
Remove the I/P lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - Right in Instrument Panel, Gauges and Console.
Caution
Unplug the blower motor before removal. Blower motor case contact with any ground may start the fan and cause personal injury.
Disconnect the blower motor electrical connector.
Disconnect the blower motor cooling tube from the HVAC module.
Remove the blower motor retaining screws.
Remove the blower motor from the HVAC module.
Installation Procedure
Install the blower motor to the HVAC module.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the blower motor retaining screws. Tighten
Tighten the screws to 1.7 N·m (15 lb in).
Connect the blower motor cooling tube to the HVAC module.
Connect the blower motor electrical connector.
Install the I/P lower insulator panel - RH. Refer to Closeout/Insulator Panel Replacement - Right in Instrument Panel, Gauges and Console.
Old Sep 23, 2009 | 06:36 AM
1jetjock's Avatar
1jetjock
Thanks for the input guys - I'll give it a try!
To Ventilation System
