Drive Train Clunk/Pop
Old Sep 23, 2009 | 09:51 AM
BELVIN20's Avatar
BELVIN20
Default Drive Train Clunk/Pop
2000 C-5, MN6, bone stock, 46K miles. When I release the clutch to go forward or reverse, I get a drive train clank or pop. I feel the noise thru the shifter when it occurs. It only does it one time, I only get the noise when I go from forward or reverse, as long as I do not change directions, no pop or clank.
Things I have done, Torque wheel lug nuts, Torque axle nuts, still no change. Never had any problem exectpt the leaky butt, took three times at GM's expense to get that fixed, so the car has been apart in the rear, however I have check everything for being tight. Any ideas?
Old Sep 26, 2009 | 11:27 PM
mdh03's Avatar
mdh03
I have a 02 Z06 - same problem ???? Do you have any other problems with rearend when driving slow and turning? It feels like the clutches in the rear locking up. if you find out please post.
Old Sep 26, 2009 | 11:41 PM
TEXHAWK0's Avatar
TEXHAWK0
Did you try backing the axle nut off, pushing the axle in, and lubricating the inner hub, bearing surface, and splines?
When rust builds up in the inner splines and hub, there is a stick/release action that will cause a pop when you reverse the load on the axles.
Just torquing the axle nuts will not always cure the problem. You need some lubrication.
Old Sep 27, 2009 | 12:17 AM
Jedimaster's Avatar
Jedimaster
I had a very similar sound and all that was needed was to remove the axle shaft, clean and lube the splines.
Old Sep 27, 2009 | 05:51 PM
mdh03's Avatar
mdh03
hey Appreciate the feed back guys will try these out.If anybody else has any ideas please post.
Old Sep 28, 2009 | 06:14 PM
TEXHAWK0's Avatar
TEXHAWK0
Here is a link with some pictures on what we are talking about.
The lube is needed where the CV hub pulls in against the back of the bearing hub, not just the splines.
http://forums.corvetteforum.com/c5-t...earings-2.html
To Drive Train Clunk/Pop
