Radioflier's light cannons
Old Sep 23, 2009 | 02:37 PM
tiojames's Avatar
tiojames
Default Radioflier's light cannons
Just finished installing Radioflier's new light cannon kit. Since I got the first kit there were a few minor problems to work out. George was very prompt and was able to get me back on track with his e-mail responses. Have not driven the car at night yet, but the difference in the garage at night when I was adjusting the lights was incredible. I would recommend the kit to anyone wanting much better lights than our cars came with. Kudos to George!!!
Old Sep 23, 2009 | 02:43 PM
Evilash's Avatar
Evilash
I found that adding an 18" section of wire between the two sides helped alot in being able to do a cleaner routing and clear the hood hinges.
Also if you have halos. I suggest putting some silicon on the ends of the heat shrink over the white connectors as water infiltraited and they arc after washing the car.
Old Sep 23, 2009 | 08:37 PM
tiojames's Avatar
tiojames
His kit requires no routing of wires from side to side and all wires go where the originals did. Only thing visible that did not come on the car is the small relay mounted at the fuse box.
To Radioflier's light cannons
