Question about wires for IAT sensor
Old Sep 26, 2009 | 10:09 AM
Venomized03's Avatar
Venomized03
Default Question about wires for IAT sensor
OK, did alot of searching but couldnt find the answer I am looking for. I have a 5 pin MAFS on my car with the IAT sensor built in. What I need to do is find out which of those 5 wires control the IAT sensor so I can cut them and run the seperate IAT sensor in a different location.
Just incase you guys are wondering why I want to do this, its because I am installing a Methanol kit on my car and I obviously have to spray it after the MAFS. So to do it the right way, I must have the IAT sensor after the meth.
THANKS IN ADVANCE
JASON
Old Sep 26, 2009 | 10:25 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The purple wire is IAT low reference (ground).
The tan wire is IAT signal to PCM.
Old Sep 26, 2009 | 10:31 AM
Venomized03
Thanks so much. I ordered a IAT sensor and pigtail from GM. Do I have to wire the sensor a certain way or does it not matter which wires go on each side?
Old Sep 26, 2009 | 10:50 AM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
On a 2 wire temperature sensor, I don't believe it matters.
It's basically just a variable resistor device, shouldn't be polarity sensitive.
Old Sep 26, 2009 | 11:26 AM
Venomized03
Thanks again. That was what I was thinking.
To Question about wires for IAT sensor
