Car wont go into gear when started
Backing out of the driveway it refused reverse like it does a lot of times. Usually running thru the gears and then going in reverse will make it work. This time it would not go into any other gear also. No funny noises, just like I'm hitting a wall. Finally after going into neutral and letting off the clutch and trying again it went into reverse. Backed it out of the driveway and put it in first and off I went. Coasted to the stop sign in neutral. Went to put it in first and no dice. Wouldn't accpt any gear. Go to neutral and release the clutch and try again and nothing, try again and nothing. Turn the car off and it goes into every gear fine. Turn car on and it will not go in any gear again. Turn car off and put it in first and leave it there. Turn the car on and off I go in gear. Try for second and its fine. Get home running thru the gears a few times and all went well.
Whats going on?
What can I check? Shifter linkage? How? Fluid levels? Check shifter itself? Sound like syncros? But every gear?
I hope it was not a clutch that did not want to disengage since I just put a new Monster stage 3 in there.
Whats going on?
Is it grinding ?
Sounds like the clutch is completely releasing and allowing you to shift.
Easiest way to check would be to pull the inspection plate and then have a buddy push in the clutch and see if is releasing properly (i.e. the disc stops spinning) also could check the air gap by sliding a feeler gauge in between the flywheel and the disc.
Lokks like it might be time for one of those tick adjustable master cylinders or be like me and convert to an automatic and get rid of all of your clutch problems
Whats going on?
Whats going on?
I have to slowly go thru forward gears before getting reverse. The only other issue is metal on metal sound when releasing the clutch. Really pronounced when cold. A few miles past 2k on a Tex z grip.....
Hope its not your Monster.
Whats going on?
Whats going on?
Read this.
http://www.ls1tech.com/forums/manual...clutch-co.html
Is it grinding ?
I have the Tick in there now. Maybe it needs an adjustment?
The day after it happened I bled the clutch (fluid looked perfectly fine) and it went into gear perfectly. In first with clutch to the floor I revved it up to 7k and it did not creep at all. Not sure if bleeding it actually helped or if its the clutch that will have intermittent problems disengaging. Going to call Mike at East Coast and see if he found out anything from Monster. I'll pull the inspection plate and see if its disengaging.
I'm praying its not the monster. It only has like 1k street miles on it. I'd hate to have to tear the car apart again.
So you installed a remote bleeder?
If you can get a hold a hand pumping vacuum tool and try reverse bleeding your clutch from the master cylinder.
Having an intermittent issue would suggest that it's not the clutch it's self but rather an issue with in the hydraulics.
Yes I installed a remote bleeder. I'm sure I can get ahold of a pump to try and get any air out that way.
Hi Nick,
You should have about 30 thousands or so of clearance between the clutch disc and the flywheel.
Have you checked your shifter bolts and alignment ?
Clutch problems are such a PIA on these cars because on the internal slaves and difficulty accessing stuff.
What kind of fluid are you running in the tranny ?
Tony
Tony
Hi Nick,
Tony
Tony
I was going to also check the shifter to make sure everything is tightened properly. Should I, or can I check the shifter linkage also?
I put AMSoil tranny fluid in some time in Feb and probably have less than 2k miles on it. I suppose I should check the fluid levels too.
Thanks, will check clearance hopefully this weekend if I have time.
Most of the shifter linkage is inside the tranny. I would just check the shifter alignment and that the shift rod is tight.
The trans fluid level and condition is probably fine unless you see some big puddles under your car.
You could try to move the clutch pedal up a bit by adjusting the rod to see if that helps with the problem.
I just hope you did not get one of those defective Monster units.
Whats going on?
Whats going on?
The C5 uses an electric Reverse Lockout device that is supposed to block reverse above 3MPH. The solenoid is mounted on top of the transmission an is very difficult to reach. There is a code for a malfunction of the coil in the solenoid (don't recall the #). You should probably check the function of the lockout before going much further. Mine was screwed up and allowed movement of the shift into reverse at speed instead of 5th!!! Ouch is right...
After re-reading the original problem, somehow I got hung up on the "won't go into reverse" part and pretty much blew off the other part... I rather doubt that my comments are of any value in this instance.
Adjusting the rod to move the pedal? Are you refering to the Tick? Will adjusting the Tick show a difference in clearance in teh clutch? If I measure clearance and it is less taht 30 thou will adjusting the Tick change that?
You taught me something new anyways. Thats always appreciated.
I called up Mike at East Coast where I got the Monster from and he said the defective clutches went out in August. I got mine in May. He says I am OK. I am praying he is right.
I'm not familiar with the Monster clutch but do they have adjustible shims that you rmove as the clutch disc wears out ?
i think its the slave
my buddies trans am did the same problem. wouldnt go into any gear when on, but when off u could. you could put in gear when off then turn it on and it would take off but u couldnt shift with clutch.
The longer the rod, the more fluid you'll push, if your clutch is dragging, which sounds to be your problem since the car will go into gear when the engine is off.
I hope not, its a brand new slave.
Been a busy 2 weeks. Had a half hour to look at the car last night. Quick checked the shifter alignment and it was not loose and looks good. I did a quick bleed of the clutch using the remote bleeder. Car went into all forward gears fine but would not go into reverse. After a few minutes of trying it went into reverse once. Backed it out of the driveway and it shifted fine going thru the gears. Got it back in the driveway and no reverse again.
Since it is not going into reverse but will accept the other gears is hydraulics a possibility? I can swing by a friends house this weekend and mity vac it to see if any more air will come out. I'll probably have time this weekend to pull the inspection plate and check clearances.
But since 1-6 are OK and reverse is a no go am I looking at another problem?
