Pfadt Coilover Poly Question
Old Sep 26, 2009 | 01:28 PM
o1Z0sick's Avatar
o1Z0sick
Default Pfadt Coilover Poly Question
I was installing my kit late last night and I was having trouble locating the poly base which is the first of the top two. I think I am missing something. There were 6 poly collars total 2 of which were just slightly shorter so not sure what to do with these. I can't post pictures yet so HERE is a link. Please let me know what I am doing wrong, I don't want to install these improperly.
Old Sep 26, 2009 | 03:03 PM
bumble-z's Avatar
bumble-z
Hi, if you need info or were short on parts, contact Jordan @ Phadt Racing. 888 972 2464. He will be more than happy to make things right for you. If you have a C/5, the ( poly base ) that you have circled, should be a softer (blk) rubber. Next is the harder soft plastic? (blk) poly collar, followed by steel washer and then the nut. Sounds as though you may be missing the softer (blk) rubber poly base. Good luck.
